It is currently Thu Jul 03, 2025 12:36 am
[ 5 posts ] |
Joel907
 Start over maybe
Ok this is my first one I don't know what I'm doing I found a 6 foot pipe that is used for making the roll cage In dragsters it not that thick of walled. Will not hold a set screw But will hold the zerks. So I welded on some nuts to hold set screws. It just going to be a 7hp longtail should I use the tube or Find somthing thicker. How tuff should the outer house be.
Sat Oct 20, 2012 10:07 pm |
autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
 Re: Start over maybe
thats for the shaft housing?? i definitely would go thicker. even if you only have 7hp, the impact is still high when you hit something. just my .02
Sat Oct 20, 2012 10:12 pm |
brianb
Joined: Mon Nov 29, 2010 6:02 pm Posts: 534 Location: louisiana
Best to use dom tube
_________________ gtr35 gt 1854 / w gatorglide 12 ft 11hp longtail 14 ft 10 hp longtail Merc 225hp TR20
Sat Oct 20, 2012 10:16 pm |
Joel907
It still DOM tube I fig you SS shaft would take most Of the force if you hit somthing. No ?
Sun Oct 21, 2012 7:01 am |
ironman_gq
the shaft transfers all of the upward shock through the bushings and into the tube, not to mention steering forces and some of the thrust load. I wouldnt go thin on the shaft tube, it will probably bend
Mon Oct 22, 2012 10:26 am |
[ 5 posts ] |
Users browsing this forum: Google [Bot] and 41 guests |
