Weed Eater Ideas? https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=38456 |
Author: | RUEHTER87 [ Thu Mar 07, 2013 11:07 am ] |
Post subject: | Weed Eater Ideas? |
Has anyone successfully built a reliable weed eater long tail? Tips? Ideas? |
Author: | T-Bubba [ Thu Mar 07, 2013 11:16 am ] |
Post subject: | Re: Weed Eater Ideas? |
lmfao ![]() |
Author: | T-Bubba [ Thu Mar 07, 2013 11:17 am ] |
i bet a 35hp long tail with some 3/8ths cable would really eat some weeds |
Author: | RUEHTER87 [ Thu Mar 07, 2013 11:22 am ] |
Yea, I bet it would eat some weeds and flare ducks sitting in a flooded millet field. |
Author: | GSUrugger [ Thu Mar 07, 2013 11:25 am ] |
google it. i believe its been tried, but those small motors do not produce NEARLY enough torque to spin a prop under load. |
Author: | T-Bubba [ Thu Mar 07, 2013 11:29 am ] |
Author: | RUEHTER87 [ Thu Mar 07, 2013 11:32 am ] |
It will be pushing a 45lb kayak and gear. I guess with the right prop it could work. As for cutting the millet, wouldnt that be baiting? |
Author: | T-Bubba [ Thu Mar 07, 2013 11:38 am ] |
Author: | RUEHTER87 [ Thu Mar 07, 2013 1:08 pm ] |
Never heard of an 80lb thrust transom mount. "EVER" What happens when the battery dies? Too much weight in a kayak anyway. |
Author: | mcduffws [ Thu Mar 07, 2013 2:50 pm ] |
a buddy of mine used to sell them, i think he still does http://www.crawdadmotors.com/ |
Author: | RUEHTER87 [ Thu Mar 07, 2013 3:28 pm ] |
I have to try to build one. This is what I have so far. 31cc with a 5 1/2" prop. |
Author: | RUEHTER87 [ Thu Mar 07, 2013 3:30 pm ] |
On a kayak |
Author: | pearl river outlaw [ Thu Mar 07, 2013 4:00 pm ] |
Here some pictures on this thread of one that I built. viewtopic.php?f=6&t=38231 |
Author: | SwampDonkey1 [ Thu Mar 07, 2013 4:40 pm ] |
Author: | RUEHTER87 [ Thu Mar 07, 2013 4:44 pm ] |
Great pics, How reliable is it? Do you still run it? |
Author: | RUEHTER87 [ Thu Mar 07, 2013 4:47 pm ] |
There is no such thing as an 80lb transom mount trolling motor. It will weigh too much, (+battery) for a kayak anyway. I have $20 in this build. I am not planning to go through straight mud. I have a MM on a boat for that. |
Author: | SwampDonkey1 [ Thu Mar 07, 2013 5:12 pm ] |
Author: | Robn1020 [ Thu Mar 07, 2013 7:15 pm ] |
Author: | RUEHTER87 [ Fri Mar 08, 2013 8:30 am ] |
Weight capacity is 300lbs-220lbs with me leaves me 80lbs for gear. A trolling battery is not practical |
Author: | Woodiebuster [ Sat Mar 09, 2013 11:29 am ] |
A 30 lb thrust trolling motor with the prop raised to the surface will go through just as much. |
Author: | deadeyedick [ Sat Mar 09, 2013 6:55 pm ] |
Author: | S.Watson [ Fri Mar 15, 2013 8:47 pm ] |
I built one like the craw daddy , using a 52cc ,there's a lot of diffrent was to go with this soccer engines , gear reductions , just look at what you want to spend |
Author: | CDMCHEVY07 [ Sat Mar 16, 2013 3:40 pm ] |
I paddle my kayak, with a paddle |
Author: | Ender [ Mon Mar 18, 2013 12:57 pm ] |
50cc (2-2.5 hp) pocket bike motor with centrifugal clutch, electric start, and charging system. Tips the scales at a 24 1/2 lbs, 27 lbs with the battery pack. Two years service and still going strong! |
Author: | deadeyedick [ Mon Mar 18, 2013 3:45 pm ] |
Sweet motor. What boat do you use it on? |
Author: | Ender [ Mon Mar 18, 2013 5:39 pm ] |
I run it on a 15 ft Michicraft canoe, but have had it on about anything from a Marsh Rat to an 18' jon. While it is not a true mud motor, it is very good in weeds and shallows. If it does load up, pop the tail, salad flies, and it is back to business. It is fairly quiet and significantly faster and lighter than my 30 lb thrust Minnkota. Unlike the electric, this motor is only limited by the fuel you carry, and will run for hours on a gallon of gas. Above all else, it was a riot to build! ![]() |
