v hull or flat bottom https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=40598 |
Author: | Powerstroke9773 [ Thu May 09, 2013 9:07 pm ] |
Post subject: | v hull or flat bottom |
Just curious i have a 20hp gdlt and im about to get a 14 foot v hull for free how will the lt do on a v hull its 14 foot by the way |
Author: | Glades Ranger [ Fri May 10, 2013 3:20 am ] |
Post subject: | Re: v hull or flat bottom |
Short answer is not so good...but it will work. A better fit would be a 15-17' hull. It all depends as well where you run and the load you carry: that 14', if it a riveter, thinner gauge hull, may require beefing up the transom area. You will have to be very careful with balancing the weight, turning, make sure you carry all requisite safety gear; make sure the kill switch works and wear the lanyard! This is most definitely a limited 2 man at most hunting boat but for free a good deal. Let us know how it goes. |
Author: | Powerstroke9773 [ Fri May 10, 2013 2:50 pm ] |
Ya i know its a bit big for the hull but what im askin is would a flat nose jon be better than a flat trans v hull |
Author: | coupe1975 [ Mon May 13, 2013 7:23 pm ] |
To the best of my knowledge is a longtail works best on a long skinny boat. I was told that a longtail works better on a flat bottom boat better then a v Hull or semi v Hull due to the fact of how the water flow from under the boat. On a flat bottom boat the water will gather up and start the head of the wake just where the longtail cav. Plate and prop ride. On a V style Hull this head of the wake is farther behind the boat making it not a efficient and harder to operate. now this is just what I've been told on mmt and unfortunately I can not verify this for you due to the fact I own a flat bottom. I ask the same question when I was looking for a rig. I was looking at a war eagle which is a semi V and was told by several people to stay away from a V so that's what I did. hope this help and you might.try to use the search feature on this site for better information |
Author: | cut'em94 [ Mon May 13, 2013 7:33 pm ] |
You will definitely see better performance on a long, skinny boat for a longtail. |
Author: | guidry21 [ Tue May 14, 2013 2:23 pm ] |
i have a 25 longtail on a semi v and the ride and performance isn to bad i can't compare it to a flat bottom tho cause ive never owned one |
Author: | Glades Ranger [ Wed May 15, 2013 6:29 am ] |
What Coupe said but I want to qualify what I posted- if you don't have a lot of mud, stumps, etc., you can get by with a semi-v like my tracker grizzly (not sure the angle of the bottom, partly vee mostly flat but has chines). I "cheated" a bit by adding steelflex (gatorglide is another product there are others) to help out over grass/mud areas by reducing friction. In those "hellilsh" marshes with all those impediments, a true flat skinny mud hull is the ticket for the LT. |
Author: | Powerstroke9773 [ Wed May 15, 2013 9:53 am ] |
It is a 14 foot skinny hull round chines flat all the way to the bow its just at the bow it comes to a V im not sure what kind of hull that makes it but it is long and skinny with flat bottom just has a V front |
Author: | Glades Ranger [ Wed May 15, 2013 12:18 pm ] |
Just use common sense and it will work fine! Can't beat the price! ![]() |
Author: | coupe1975 [ Thu May 16, 2013 7:10 pm ] |
X2^ but watch the semi v on the front on the boat because if you(sorry) when you hit a stump just under the water if its not dead center the boat will jump hard to the left or right so be sure to have a grab bar and WEAR your saftey kill switch and made sure it works. Because you may go swimming easier than with a flat bottom due to the angle on the bottom will catch the stump like a ramp. Good luck |
Author: | Powerstroke9773 [ Thu May 16, 2013 9:15 pm ] |
Ya thanks a lot guys i figured it would work iv looked at some of the mud run photos and seen guys running v feonts just wanted to get yals opinion its greatly appreciated how much more balls you think the 20hp will have compared to the 13 i used to have |
Author: | coupe1975 [ Sat May 18, 2013 4:18 pm ] |
Night and day difference |
Author: | tylerduckman [ Sat May 18, 2013 6:34 pm ] |
Flat bottom!! The only way to go |
