13HP longtail
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=42976
Author:  Baddodge [ Tue Jul 16, 2013 11:17 am ]
Post subject:  13HP longtail
getting all my parts together to start my 2nd build and had a generic question. I see where some are using a flange bearing on top and was curious if you are putting a seal behind that bearing housing or just letting the grease go all the way up to the back of the bearing housing. Theres a grease fitting on the bearing itself so no need to let the grease from housing service the bearing, and not having a seal on the top end of the shaft would also create a leak point for the grease. just curious.
Author:  Simsknives [ Mon Jul 22, 2013 6:01 pm ]
Post subject:  Re: 13HP longtail
I just use some of the red gasket sealant on mine and haven't had any problems. My top flange bearing is shielded and sealed.
Author:  ds541 [ Mon Jul 22, 2013 8:32 pm ]
I think i'd go with a couple of seals behind the flange bearings just to make sure you keep the grease in and the water out.
Author:  Baddodge [ Tue Jul 23, 2013 11:02 am ]
Kinda what I was thinking. I posted sketches of what I am going to do with the bushings, bearings, and seals in the thread titled threading the OD of dom tube.
Author:  Cameron_z7 [ Wed Oct 23, 2013 1:35 pm ]
What kind of grease seals do y'all use? Rotary shaft seals or what?
Author:  Baddodge [ Sat Oct 26, 2013 4:08 pm ]
I just used double lip spring loader oil seals. Search honda gx 390 build. I put lots of pictures in that thread and you can see the seals there.
