It is currently Mon Jun 30, 2025 4:45 am
Reply to topic  [ 3 posts ]
 Shortening skeg
Post Shortening skeg
After reading woodie busters broken skeg story I started thinking of shortening the skeg up a little bit. Most of my running I am doing the cav plate is out of the water a good bit. Usually 8 " of water. If I would shave 2" off the skeg it would help out some. Anyone do that? I hate to mess with original equipment or try to reinvent the wheel but mudn is like sex. It's a game of inches
23 swomp/ 1542 tracker
Sun Oct 20, 2013 7:15 pm
Post Re: Shortening skeg
As long as it has enough on it to bounce up an protect that prop... a skeg strike isnt even close to a prop strike when your muscling the longtail in inches of water...
1436 Lowe
Sun Oct 20, 2013 8:03 pm
I tried that a couple of years ago, shaved 2" off. Amazing how less surface area in the water makes steering easier, less "drag", but ended up putting some of it back on after I sheared a flywheel key on a prop strike. I put a straight edge from the bottom tip of the prop back to the shaft at normal running position water level and added back enough to put the skeg tip even with the bottom of the prop at this angle - haven't had a problem since...
The key to a successful marriage?
Give a man a 4X4 truck, a rifle, a shotgun, a Mud boat, and a fishing pole - he will be out of your hair most of the year...
Mon Oct 21, 2013 6:27 am
Users browsing this forum: No registered users and 43 guests
