23 hp vanny power loss https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=46537 |
Author: | bfrost12 [ Sat Oct 19, 2013 7:52 am ] |
Post subject: | 23 hp vanny power loss |
Losing power when we put the prop in the water. Runs fine outside the water. The motor is falling on its' face when the prop hits the water. Thoughts? Thanks! |
Author: | Broadriverboy [ Sat Oct 19, 2013 9:13 pm ] |
Post subject: | Re: 23 hp vanny power loss |
Clean carb 23 gdlt did the same thing it was the bottom 2 jets clogged out of 4 total |
Author: | p5388 [ Sat Oct 19, 2013 9:38 pm ] |
Also, check your spark plugs, foul 1 and it runs fine unloaded, but won't take a load... |
Author: | Joe Guide [ Sun Oct 20, 2013 4:10 am ] |
If it had been making "popping sounds" with severe loss of power, do a leak down test, and you will find it is probably one of the coils...went bad. Better replace both of em when you do. |
Author: | SwampDonkey1 [ Mon Oct 21, 2013 10:39 am ] |
Might also want to check on your cavitation plate, if mounted too steep the load applied will sometimes cause the motor to die out. Kinda like killing out a lawn mower by running it through real thick grass too quickly. |
Author: | Dono [ Tue Oct 22, 2013 9:38 am ] |
Could be low on oil...I had this problem, and it was the oil level on my dip stik was wrong. I added oil, and that fixed my vacuum. |
