It is currently Mon Jun 30, 2025 5:00 am
Reply to topic  [ 9 posts ]
 need help and input on average boat speeds.
Post need help and input on average boat speeds.
i have a 16/48 with a coast guard bow and ribbed bottom. im running a 25hp kholer on a mudbuddy lt. yes I know that's not much of a mud boat but its wat I got. im concerned with speeds. it seems slower than some speeds mentioned on here and im jst courious on wat some of you guys are getting. I didn't have my gps with me today so im not exactly sure of speed but deffinitly slow. this is with just me battery and 5gal gas running in open water and with a brand new prop. its a backwater 9x6 and when I got it I was very surprised on the lack of cupping. also I saw on here about length of shaft to transom height also wondering about that. I will post later shaft length and transom height. so let me know guys. thanks!!!!
Sun Oct 27, 2013 3:49 pm
Post Re: need help and input on average boat speeds.
Take a look at the database in my signature below.
Sun Oct 27, 2013 4:10 pm
20'' transom and approx. 7' shaft length
Sun Oct 27, 2013 4:50 pm
Wondering what slow is. Its not a SD. 1542 with 23hp just me I am at 20. Add 400lbs I am at 15ish. I don't know what a coastguard bow is.
23 swomp/ 1542 tracker
Sun Oct 27, 2013 5:10 pm
I'm running a 16x48 ribbed bottom, with a 23GDLT. Just me with a light load in deep water i'm running 18.5 mph on gps.
Mon Oct 28, 2013 11:46 am
I used to have a 1648 ribbed boat with a 25 GDLT and it ran 19.5-20 with just me in it. Open floor on it
Loaded down around 13-15
Mon Oct 28, 2013 3:57 pm
I run a 1648 flat bottom ribbed 25 hp mblt 9x7 prop, run 17 mph 2 guys 1dog decoys and gear. Empty close to twenty. Weight is everything in these boats one more guy expect to lose 2 to 4 mph.
Mon Nov 04, 2013 10:12 pm
1648 grizzly w/27 HP LT- the speeds are just like those previous posters...make sure you get a tiny tach to check your idle rpms and rpms in general. Your BackH20 angle/cavitation plate will probably need adjustment for that high transom; you might also tweak/advance the throttle up to 4100 rpm. These speeds are about all you can expect. Your elevation could be a factor but I don't know that or how you compensate- I am close to sea level so no factor. As was stated, balance your weight, hulls are different and you find out by trial and error. Go synthetic with the oil and grease. Gatorglide, quickslick, or steelflex is another plus on the hull bottom.
Wed Nov 06, 2013 4:11 am
I had a 25 mud buddy lt on my 15/42 semi v. by myself I could do low 20s three people I would get 17. me, wife, and my daughter 18-19 consistant
16x48 alweld
35 gtr
Thu Nov 07, 2013 11:17 am
Users browsing this forum: Google [Bot] and 47 guests
