nv92
 need help and input on average boat speeds.
i have a 16/48 with a coast guard bow and ribbed bottom. im running a 25hp kholer on a mudbuddy lt. yes I know that's not much of a mud boat but its wat I got. im concerned with speeds. it seems slower than some speeds mentioned on here and im jst courious on wat some of you guys are getting. I didn't have my gps with me today so im not exactly sure of speed but deffinitly slow. this is with just me battery and 5gal gas running in open water and with a brand new prop. its a backwater 9x6 and when I got it I was very surprised on the lack of cupping. also I saw on here about length of shaft to transom height also wondering about that. I will post later shaft length and transom height. so let me know guys. thanks!!!!
Sun Oct 27, 2013 3:49 pm |
dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
 Re: need help and input on average boat speeds.
Take a look at the database in my signature below.
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
Sun Oct 27, 2013 4:10 pm |
nv92
20'' transom and approx. 7' shaft length
Sun Oct 27, 2013 4:50 pm |
Trousertrout
Joined: Tue Oct 18, 2011 3:18 pm Posts: 1060 Location: Ohio-The land of few ducks
Wondering what slow is. Its not a SD. 1542 with 23hp just me I am at 20. Add 400lbs I am at 15ish. I don't know what a coastguard bow is.
_________________ 23 swomp/ 1542 tracker
Sun Oct 27, 2013 5:10 pm |
Rebel05
Joined: Mon Jun 03, 2013 2:47 pm Posts: 25 Location: Baton Rouge, La.
I'm running a 16x48 ribbed bottom, with a 23GDLT. Just me with a light load in deep water i'm running 18.5 mph on gps.
Mon Oct 28, 2013 11:46 am |
d_white
I used to have a 1648 ribbed boat with a 25 GDLT and it ran 19.5-20 with just me in it. Open floor on it Loaded down around 13-15
Mon Oct 28, 2013 3:57 pm |
swamprunner09
I run a 1648 flat bottom ribbed 25 hp mblt 9x7 prop, run 17 mph 2 guys 1dog decoys and gear. Empty close to twenty. Weight is everything in these boats one more guy expect to lose 2 to 4 mph.
Mon Nov 04, 2013 10:12 pm |
Glades Ranger
1648 grizzly w/27 HP LT- the speeds are just like those previous posters...make sure you get a tiny tach to check your idle rpms and rpms in general. Your BackH20 angle/cavitation plate will probably need adjustment for that high transom; you might also tweak/advance the throttle up to 4100 rpm. These speeds are about all you can expect. Your elevation could be a factor but I don't know that or how you compensate- I am close to sea level so no factor. As was stated, balance your weight, hulls are different and you find out by trial and error. Go synthetic with the oil and grease. Gatorglide, quickslick, or steelflex is another plus on the hull bottom.
Wed Nov 06, 2013 4:11 am |
guidry21
Joined: Thu Feb 14, 2013 1:33 pm Posts: 338 Location: galliano, la
I had a 25 mud buddy lt on my 15/42 semi v. by myself I could do low 20s three people I would get 17. me, wife, and my daughter 18-19 consistant
_________________ 16x48 alweld 35 gtr
Thu Nov 07, 2013 11:17 am |
