Water in shaft housing? https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=47322 |
Author: | jedisme [ Tue Nov 12, 2013 5:03 pm ] |
Post subject: | Water in shaft housing? |
Ugh!! Have water somehow getting into my shaft housing 23 HP vanguard GD no play in the prop so I assume the bushing is good. |
Author: | huck Finn [ Tue Nov 12, 2013 5:22 pm ] |
Post subject: | Re: Water in shaft housing? |
Lower seals ? H Finn |
Author: | SETx Longtail [ Tue Nov 12, 2013 6:51 pm ] |
Lower seals being bad is about the only way that's possible.... Unless you have somehow mounted your motor to the bottom of the boat instead of the top lol |
Author: | kibb [ Tue Nov 12, 2013 7:18 pm ] |
Clean the grass from in between the nut and seal housing after every trip. That shit dries out like rope and eats seals. |
Author: | coupe1975 [ Tue Nov 12, 2013 8:20 pm ] |
Author: | jedisme [ Thu Nov 14, 2013 7:22 pm ] |
Is it a grease seal or an oil seal? |
Author: | SETx Longtail [ Thu Nov 14, 2013 7:30 pm ] |
Grease seal |
Author: | kibb [ Thu Nov 14, 2013 10:02 pm ] |
FYI, old style is two seals back to back. New style is two seals back to back and a scraper seal. Scraper seal is closest to the prop and the side with writing faces the engine. |
Author: | jedisme [ Thu Nov 14, 2013 10:46 pm ] |
Thank you all! I believe it is a newer style. I could more than likely get the grease seals from Napa? I would just order them from GD but I need to get this resolved this weekend., |
Author: | kibb [ Thu Nov 14, 2013 11:08 pm ] |
You may find something that will get you by, but I believe the ones from GD are a proprietary design that's manufactured for them. |
Author: | dead duk [ Sun Nov 17, 2013 7:14 am ] |
In addition to Kibb...How do you store your motor? If you store it outside and uncovered, you could have water intrusion from the top near the universal joint. Unlikely, but I would check to rule it out. |
