16hp long tail on 14 foot riveted boat?
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=47519
Author:  dmontz_14 [ Mon Nov 18, 2013 8:50 pm ]
Post subject:  16hp long tail on 14 foot riveted boat?
How do you guys think a 16hp long tail go devil would do on a 14 foot riveted flat boat?
Author:  North LA Hunter [ Mon Nov 18, 2013 8:57 pm ]
It runs good enough! Know a guy that ran one on a 1436 and it was a little heavy but got the job done.
Sent from my beeper.
Author:  dmontz_14 [ Mon Nov 18, 2013 9:34 pm ]
Post subject:  Re: 16hp long tail on 14 foot riveted boat?
What you think the top speed would be?
Author:  da go get'er [ Mon Nov 18, 2013 10:09 pm ]
Author:  SwampDonkey1 [ Tue Nov 19, 2013 12:42 am ]
I run a 16hp single cylinder on a 1436 riveted and hit 16 or so empty but with a heavy hunting load itll usually hang around 10 but still pushes through the crud...
Author:  btmannin [ Tue Nov 19, 2013 2:11 am ]
fresh prop you'll run 17-19 empty 13-15 with 2 ppl and light load.. 12 with 2 ppl/dog hunt load.. 3 ppl there is no stepping it
Author:  btmannin [ Tue Nov 19, 2013 2:12 am ]
fresh prop you'll run 17-19 empty 13-15 with 2 ppl and light load.. 12 with 2 ppl/dog/ hunt load.. 3 ppl/ hunt load there is no stepping it
Author:  Honky Kong [ Fri Nov 22, 2013 8:17 pm ]
I would think you'd be fine. How wide is the boat? I have a 23hp backh20 SWOMP (175 lbs) on a 14 ft. Mod-v Jon. It's 48 inches wide at the bottom.
Author:  huck Finn [ Fri Nov 22, 2013 8:32 pm ]
I ran a. 16 lt for years , 15'x36 skiff. , pushed that thing fine . Coupe 75 has that motor now on a 14' crawfish hull and it runs fine , call me crazy but I put a 25 GD lt on my 15x36 skiff , not much noticeable speed difference. , but it pushes a heavier load easier. .
H Finn
Author:  honkertalker [ Fri Nov 29, 2013 6:54 pm ]
i got a 6.5 predator on a 1436 runs 13-14 with just me and 10 with 2 people and normal hunt load
Author:  SouthernWake [ Sat Nov 30, 2013 7:20 am ]
I run a 20 hp longtail on an ol riveted 1436. No problems with it as far as water coming over that back or in on turns. Just don't go crossin any oceans with it.
Author:  Jw261 [ Tue Dec 03, 2013 7:23 am ]
I had a 16LT on a Tracker 15. It ran about 15mph loaded with two guys. I considered replacing it with some of the smaller surface drives on the market, but ended up with a whole new rig. If you're that worried about speeds, looks at some of them. I got a little nervous after researching them though. I found alot of reviews that kind of pushed me away from getting one.
Author:  Boudreaux76 [ Mon Dec 09, 2013 9:49 pm ]
I run a 20hp beavertail on a riveted 1436... I'm never going to set a land speed record but there's very few places I can't get.
Author:  coupe1975 [ Tue Dec 10, 2013 8:08 am ]
Got a 16hp longtail godevil on a 14x36 crawdad and it floats and handles it fine. I am not setting a speed record with it but it runs 16 unloaded 15 loaded. Goes anywhere I dare to take it. A longer boat would improve speed due to more planing surface. 14x36 will take the 16 with no problem.
Author:  Delta1389 [ Tue Dec 10, 2013 9:15 am ]
