It is currently Mon Jun 30, 2025 1:45 am
Reply to topic  [ 18 posts ]
 bearing question
Post bearing question
still doing r & d for my home build LT.would to add a bearing instead of the upper bushing,any one have any good ideas that would save me from screwing things up.pic's would help.
Wed Sep 19, 2012 7:51 pm
Post Re: bearing question
I saw it posted just recently, but we weld a plate to the end of the shaft housing with a hole in the middle, drill holes to mount a pillow block or you can use another bearing assembly that sandwiches a bearing between two mounting plates. Just something that will be sealed, and is easy to unbolt if you must replace it.
1436 Lowe
Wed Sep 19, 2012 11:08 pm
thanks for the reply,i thought of just using a pillow bearing after i posted the question.guess i was over just over thinking things.
Thu Sep 20, 2012 9:59 pm
I had gotten a gas pipe fitting that screwed down onto the shaft housing pipe and had the other end of it machined to have a sealed roller bearing pressed in it and it works great and is removable i looked for the pic i had on hear but it wasnt able to be pulled up for some reason so i will take another pic if you are still interested
Sun Sep 23, 2012 1:17 pm
[quote="jp0242"]I had gotten a gas pipe fitting that screwed down onto the shaft housing pipe and had the other end of it machined to have a sealed roller bearing pressed in it and it works great and is removable i looked for the pic i had on hear but it wasnt able to be pulled up for some reason so i will take another pic if you are still interested[/quote
thank-you very much, i would like to see a picture of your set up, i'm still in the r&d phase of my build due to the fact hunting season starts very soon.and i'm looking at all options.
Sun Sep 23, 2012 10:07 pm
Here are some pic like I said it screws onto the shaft housing pipe that the old godevil seal cap screwed to and the other end of it I had machined and a bearing pressed in I had to use a lil sandpaper to get the shaft to fit perfect but its good now only leaks a small amount of grease pass it and cost about $10 minus the machining cost got lucky and had a friend do it for me good luck hope this helps
Sent from my HTCEVODesign4G using Tapatalk 2
Tue Sep 25, 2012 3:35 am
It's a bit more expensive but on my last longtail build I ordered a top bearing housing from Beavertail and had a plumber buddy thread the top of the shaft tube for it. I believe I paid about $100 for the housing and it has a built-in bearing and seal, simple and easy.
Tue Sep 25, 2012 12:23 pm
thanks for the idea and thats a nice looking home build you've got going there,
what size motor are you using.
Tue Sep 25, 2012 9:16 pm
jp0242 thanks for posting the pics of your home built bearing. i went out today and tracked down the hex bushing ,now i need to match up a sealed bearing then figure out how to put the too together.
Tue Sep 25, 2012 9:23 pm
I'll try to get the number on the bearing later today for you so you can just get one and take it to a machine shop and they can do the rest
Wed Sep 26, 2012 7:28 am
ds-that one was for a 13hp motor.
Wed Sep 26, 2012 2:33 pm
Wed Sep 26, 2012 5:45 pm
pumpgunner- did you use the mad mud motor plans for that frame build, i can only hope my first build turns out half as nice as that one.
Wed Sep 26, 2012 5:51 pm
ds-I built my first longtail from the Mad plans, they are a good starting point but there are a few things on there I would change. They are really good for getting part numbers, etc. That frame in the picture is pretty much a new design with some elements from the Mad plans. It sounds like you are on the right track with yours!
Thu Sep 27, 2012 12:19 pm
Bearing #6203-2rs-3/4
Thu Sep 27, 2012 2:48 pm
thanks-guys!
Thu Sep 27, 2012 5:45 pm
where did you get those u joints from
Sun Dec 01, 2013 5:57 pm
Search for "13 horse honda gx390 build" I put a ton of pictures in that thread. im also attaching a picture of all the bearings and seals i used for my build.
Mon Dec 02, 2013 12:49 pm
Users browsing this forum: No registered users and 47 guests
