It is currently Mon Jun 30, 2025 7:01 am
Reply to topic  [ 5 posts ]
 Go devil problem
Post Go devil problem
A buddy has a go devil long tail that is having issues. It runs fine out the water but as soon as he puts it in the water it wants to die. What is wrong it? He is thinking carb problem
Tue Dec 03, 2013 9:04 pm
Post Re: Go devil problem
First thing that comes to mind is it isn't running on both cylinders - common problem being the diode in the kill wires gone bad causing 1 coil pack to "kill" the other... You can check by pulling 1 spark plug wire with the engine running - if it dies, that's the "dead" cylinder, if it still runs, try pulling the other spark plug wire (1st put the 1 you just pulled back on - lol!)
The key to a successful marriage?
Give a man a 4X4 truck, a rifle, a shotgun, a Mud boat, and a fishing pole - he will be out of your hair most of the year...
Tue Dec 03, 2013 9:26 pm
X2 on check the coils. Also diode may have gone bad. Mine did replaced both coils then I realized diode wire was fried.
Tue Dec 03, 2013 9:41 pm
Mine was doing something similar. Except only at wot in the water. Ended up having to rebuild the carb
Wed Dec 04, 2013 9:12 pm
Who makes the motor???? What hp??
That's a decent start , sounds like carb to me
Wed Dec 04, 2013 9:32 pm
Users browsing this forum: No registered users and 47 guests
