It is currently Tue Dec 23, 2025 9:07 pm
Reply to topic  [ 7 posts ]
 20hp Honda Engine Beavertail Longtail Info
Post 20hp Honda Engine Beavertail Longtail Info
Hello guys. I am new to mud motors and could really use your help. I just picked up a Beavertail longtail with a Honda gx620 20hp engine. I rebuilt the carbs on this thing today and need to know what the revs should be at idle and WOT while outside of the water. The engine has a tiny tach hooked up to it. It is spinning a 9x5 prop that has very little wear. I have ordered the plugs, fuel filter, oil filter, air filter and will be cleaning up both the engine and longtail this weekend. What do you recommend for greasing the shaft? Do I just hook up my grease gun to the only zerk fitting on the longtail and go to town? Please advise me as I am lost. I tried to find literature on the beavertail website but did not see much. The longtail will be pushing a Polar Kraft 1442. Any help would be greatly appreciated. Thanks
Jimmy
1442 Polar Kraft/ 20HP Beavertail LT
Thu Sep 25, 2014 9:20 pm
Post Re: 20hp Honda Engine Beavertail Longtail Info
Have the same problem on my 20 hp beaver tail don't know Wat rpms should be running.
Fri Oct 31, 2014 2:46 pm
on my gtr i set my idle in the water in gear that way you dont set it to low that it will kill when you hit the water....as far as rpms on that 20hp i would call a local dealer and ask them http://cdn.powerequipment.honda.com/eng ... ZJ1611.pdf
07 16x50 w/ 07 35 gtr
Fri Oct 31, 2014 2:52 pm
I typically turn my GX620 around 4000. Don't be scared to spin that thing, it's not a Briggs ;)
-Custom pool noodle
-stage 4 water wings
Fri Oct 31, 2014 4:25 pm
in the water i run 4080 something but my idles a little more than 2000 i think
Fri Oct 31, 2014 8:08 pm
Should be idling around 1000-1100, out of water mine idles about 1400-1500,
-Custom pool noodle
Sun Nov 02, 2014 7:19 am
When the governor is surging this means the mixing screw isn't set right correct?
Sun Nov 02, 2014 4:45 pm
