It is currently Sun Jun 29, 2025 6:01 am
Reply to topic  [ 26 posts ]
 New Build....212cc 7 hp Predator longtail ( top speed? )
Post New Build....212cc 7 hp Predator longtail ( top speed? )
Finally done!
Stock ( for now ) Harbor Freight 212cc engine
Direct drive 6ft shaft
7" SPS aluminum prop ( Dont hate unless you wanna buy me a stainless one!) :lol:
11 mph top speed by myself on a 14x36 Duracraft
10 mph loaded with 2 180lb guys and a spare 4 stroke engine
I may try a larger SPS prop, their cheap enough to experiment with!
Any mathmaticians on here that can determine if a bigger prop will help top end?
Appreciate all the info on here about homemade builds cause everybody don't have the spare $$$$$$
to drop on a store bought unit.
Mon Dec 23, 2013 2:34 pm
Post Re: New Build....212cc 7 hp Predator longtail ( top speed? )
How did you get a 7inch sps prop to fit a 3/4 threaded shaft?
Mon Dec 23, 2013 4:32 pm
I had a machine shop make an adapter.
Mon Dec 23, 2013 5:09 pm
I run a 7x5 prop with that engine if it is a straight drive with out a reduction to the drive shaft.
Mark F. Cheney
on the Great Salt Lake marsh
Mon Dec 23, 2013 6:41 pm
You will have a SS prop soon. You didn't hit any fish,turtles,frogs or leaves on your test run. I know from experience.Think your prop is oversized now. Need to know rpms
23 swomp/ 1542 tracker
Mon Dec 23, 2013 6:59 pm
That's really neat so I take it screws on the shaft ?
What's the other end look like I might have one built for mine so I can keep a back up prop in the boat.
Mon Dec 23, 2013 8:27 pm
I guess I need to pick up a tachometer. Think 7" may be too large for 7hp?
It don't bog down at all. I find it kind of odd that it runs dang near the same speed
Loaded down or empty. I would love to see a few more mph out of it eventually.
Mon Dec 23, 2013 8:36 pm
Joel, the 3/4 shaft is smooth at both ends and through bolted with 1/4" grade 8 bolts and lock nuts. The pic of the adapter is before the hole was drilled.
Mon Dec 23, 2013 8:56 pm
I would throw a 6 on there to see what happens. Like you said they are cheap so why not. The tach will tell all
Mon Dec 23, 2013 9:40 pm
Wed Dec 25, 2013 7:23 pm
I will try a 6" and see how it goes. I may be expecting too much for a 212cc pushing a 1436 Duracrft!
What size boats are you pushing with a 6" prop? What's kind of speeds are you getting?
Sat Dec 28, 2013 4:56 pm
I had a 7" on a 13hp pushing a 1542 around 15mph with 2 guys,dog and decoys
Sat Dec 28, 2013 6:08 pm
6" prop just came in! I hope to try it out this weekend and will post an update on speed rather
It be slower or faster. If nothing else, I got a spare now.
Mon Jan 06, 2014 11:43 am
I think you will find the 6 inch prop to small. Should have ordered the 6.5 inch.
Mon Jan 06, 2014 2:46 pm
Mon Jan 13, 2014 8:21 pm
Mon Jan 13, 2014 8:42 pm
Natty light tall boyz. Woooooooooooooooooooo. Got my 2nd DUI thanks to those back in he day
Mon Jan 13, 2014 9:08 pm
Looks good. What did you use for bushings and seals?
Mon Jan 13, 2014 10:15 pm
Thanks. Seals and brass bushings from McMaster. Doesn't leak oil and shaft spins freely. I was going to change to bearings if the bushings didn't work but they work fine.
Tue Jan 14, 2014 5:50 am
Stage 2 Mini 23 chasing a 1642 Prodigy
Tue Jan 14, 2014 6:28 am
My boat weighs 100 pounds. So that's probably a big factor.
Tue Jan 14, 2014 8:33 am
Update....adjusted the throttle stop on the engine until right before the governor
Kicks in and added a Cheap straight through exhaust. Loud at high RPM .Same 1436 boat with same 7 inch prop with about 200 extra pound in the Boat including my 5 year old son in the front........same GPS.......15 mph...getting better......
Sun Mar 09, 2014 3:19 pm
Have ran it my yourself since the changes?
Sun Mar 09, 2014 3:25 pm
That is today's speeds, 15 mph
Pissed all the Bass Fisherman off!
Sounds like a single cylinder Harley!
Sun Mar 09, 2014 4:57 pm
Mudslinger- Have ran it my yourself since the changes?
Ahhhh...by myself? No. I will have to try it when I don't have my son with me. Might see 16?
Sun Mar 09, 2014 5:52 pm
Oh, and nice build ghetto, I would love to try mine on a lighter/narrower boat and see what it does. I hope to evenually hit 20 mph
Sun Mar 09, 2014 5:58 pm
Users browsing this forum: No registered users and 52 guests
