New Build....212cc 7 hp Predator longtail ( top speed? ) https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=48557 |
Author: | DuckyStyle [ Mon Dec 23, 2013 2:34 pm ] |
Post subject: | New Build....212cc 7 hp Predator longtail ( top speed? ) |
Finally done! Stock ( for now ) Harbor Freight 212cc engine Direct drive 6ft shaft 7" SPS aluminum prop ( Dont hate unless you wanna buy me a stainless one!) ![]() 11 mph top speed by myself on a 14x36 Duracraft 10 mph loaded with 2 180lb guys and a spare 4 stroke engine I may try a larger SPS prop, their cheap enough to experiment with! Any mathmaticians on here that can determine if a bigger prop will help top end? Appreciate all the info on here about homemade builds cause everybody don't have the spare $$$$$$ to drop on a store bought unit. |
Author: | Joel907 [ Mon Dec 23, 2013 4:32 pm ] |
Post subject: | Re: New Build....212cc 7 hp Predator longtail ( top speed? ) |
How did you get a 7inch sps prop to fit a 3/4 threaded shaft? |
Author: | DuckyStyle [ Mon Dec 23, 2013 5:09 pm ] |
I had a machine shop make an adapter. |
Author: | Mark F. Cheney [ Mon Dec 23, 2013 6:41 pm ] |
I run a 7x5 prop with that engine if it is a straight drive with out a reduction to the drive shaft. Mark F. Cheney |
Author: | Trousertrout [ Mon Dec 23, 2013 6:59 pm ] |
You will have a SS prop soon. You didn't hit any fish,turtles,frogs or leaves on your test run. I know from experience.Think your prop is oversized now. Need to know rpms |
Author: | Joel907 [ Mon Dec 23, 2013 8:27 pm ] |
That's really neat so I take it screws on the shaft ? What's the other end look like I might have one built for mine so I can keep a back up prop in the boat. |
Author: | DuckyStyle [ Mon Dec 23, 2013 8:36 pm ] |
I guess I need to pick up a tachometer. Think 7" may be too large for 7hp? It don't bog down at all. I find it kind of odd that it runs dang near the same speed Loaded down or empty. I would love to see a few more mph out of it eventually. |
Author: | DuckyStyle [ Mon Dec 23, 2013 8:56 pm ] |
Joel, the 3/4 shaft is smooth at both ends and through bolted with 1/4" grade 8 bolts and lock nuts. The pic of the adapter is before the hole was drilled. |
Author: | Trousertrout [ Mon Dec 23, 2013 9:40 pm ] |
I would throw a 6 on there to see what happens. Like you said they are cheap so why not. The tach will tell all |
Author: | dogyak [ Wed Dec 25, 2013 7:23 pm ] |
Author: | DuckyStyle [ Sat Dec 28, 2013 4:56 pm ] |
I will try a 6" and see how it goes. I may be expecting too much for a 212cc pushing a 1436 Duracrft! What size boats are you pushing with a 6" prop? What's kind of speeds are you getting? |
Author: | Trousertrout [ Sat Dec 28, 2013 6:08 pm ] |
I had a 7" on a 13hp pushing a 1542 around 15mph with 2 guys,dog and decoys |
Author: | DuckyStyle [ Mon Jan 06, 2014 11:43 am ] |
6" prop just came in! I hope to try it out this weekend and will post an update on speed rather It be slower or faster. If nothing else, I got a spare now. |
Author: | goose-em [ Mon Jan 06, 2014 2:46 pm ] |
I think you will find the 6 inch prop to small. Should have ordered the 6.5 inch. |
Author: | ghetto [ Mon Jan 13, 2014 8:21 pm ] |
Author: | ghetto [ Mon Jan 13, 2014 8:42 pm ] |
Author: | Trousertrout [ Mon Jan 13, 2014 9:08 pm ] |
Natty light tall boyz. Woooooooooooooooooooo. Got my 2nd DUI thanks to those back in he day |
Author: | Will C [ Mon Jan 13, 2014 10:15 pm ] |
Looks good. What did you use for bushings and seals? |
Author: | ghetto [ Tue Jan 14, 2014 5:50 am ] |
Thanks. Seals and brass bushings from McMaster. Doesn't leak oil and shaft spins freely. I was going to change to bearings if the bushings didn't work but they work fine. |
Author: | dillakilla12 [ Tue Jan 14, 2014 6:28 am ] |
Author: | ghetto [ Tue Jan 14, 2014 8:33 am ] |
My boat weighs 100 pounds. So that's probably a big factor. |
Author: | DuckyStyle [ Sun Mar 09, 2014 3:19 pm ] |
Update....adjusted the throttle stop on the engine until right before the governor Kicks in and added a Cheap straight through exhaust. Loud at high RPM .Same 1436 boat with same 7 inch prop with about 200 extra pound in the Boat including my 5 year old son in the front........same GPS.......15 mph...getting better...... |
Author: | mud slinger 69 [ Sun Mar 09, 2014 3:25 pm ] |
Have ran it my yourself since the changes? |
Author: | DuckyStyle [ Sun Mar 09, 2014 4:57 pm ] |
That is today's speeds, 15 mph Pissed all the Bass Fisherman off! Sounds like a single cylinder Harley! |
Author: | DuckyStyle [ Sun Mar 09, 2014 5:52 pm ] |
Mudslinger- Have ran it my yourself since the changes? Ahhhh...by myself? No. I will have to try it when I don't have my son with me. Might see 16? |
Author: | DuckyStyle [ Sun Mar 09, 2014 5:58 pm ] |
Oh, and nice build ghetto, I would love to try mine on a lighter/narrower boat and see what it does. I hope to evenually hit 20 mph |
