It is currently Sun Jun 29, 2025 6:52 am
Reply to topic  [ 3 posts ]
 Beavertail/Honda 13hp Upgrades
Post Beavertail/Honda 13hp Upgrades
Any bolt-on upgrades that would help squeeze a bit more power out of my GX motor? It looks like this is a fairly popular karting engine, have found a few parts, carbs, cams etc. online... anyone have any experience that can vouch for the results of these upgrades? - Im not looing for 1/10th of a second on the track but hopefully some noticable difference in speed and push through the muck...
Mon Dec 30, 2013 9:31 am
Post Re: Beavertail/Honda 13hp Upgrades
Get a candy cane header and rejet the carb. Also add an aftermarket air filter/more open. Then pull out the governor if you haven't already.
Mon Dec 30, 2013 8:48 pm
I have looked at this question long and hard for several years. If you're going to mess with your motor:
There are some good tutorials on affordable go karts web site
put a tack on it. stock components will generally go to 5,000 Rpm with out a problem. A tack will keep you out of trouble , they are cheep and give invaluable feed back.
up grades are worthless with the governor still in the motor.
the most bang for the buck comes from a more free flowing exhaust.This is next after a tack.
You should rejet the carb to get the max out of exhaust improvements. This is just a bit of fiddleing to do and costs maby $5 - 6.
after the above you will probably need a new prop to take advantage of the difference. This is likely to be the most expensive part of the up grade.
Mark F. Cheney
on the Great Salt Lake marsh
Tue Dec 31, 2013 4:52 am
Users browsing this forum: No registered users and 48 guests
