It is currently Sun Jun 29, 2025 9:10 am
Reply to topic  [ 7 posts ]
 New gdlt
Post New gdlt
Hello guys,
I just picked up a 16 briggs gd on a 15-36 crawfish skiff. When i first tried it, the cav plate was bent up wards and the prop would dive hard, making it impossible to steer. I fixed this. Now when im running, it wants to push into my leg, if i let it go, it will self steer slowly to the right
Im trying to set the skag and cav plate to run with little to no constant strain on my arm and shoulder
How is yours set? Do you run so that the prop dives or kicks itself out of the water? Does your gd constantly push one way or the other?
Thanks, dave
Sent from my a/c thermostat
Mon Jan 20, 2014 9:28 pm
Post Re: New gdlt
Keep playing with the plate until it runs nice and even just under the surface. Never noticed mine pulling one direction or the other. You sure it is square on the boat? Maybe a little more weight on one side? You shouldn't have to man handle it while running. Once everything is right should be able to just guide it along.
Mon Jan 20, 2014 9:43 pm
Post Re: New gdlt
The cavitation plate should ride right below the waters surface. The boat is pulling because the boat is not balanced. Shift some weight around until it is balanced. When everything is set right you should be able to let go of the handle and steer somewhat by leaning to one side or the other.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Post Re: New gdlt
Thanks fellas, i will try this next time im out.
Tue Jan 21, 2014 6:10 am
Post Re: New gdlt
Tue Jan 21, 2014 6:11 am
Post Re: New gdlt
Tue Jan 21, 2014 6:12 am
Post New gdlt
Tue Jan 21, 2014 6:26 am
Users browsing this forum: No registered users and 54 guests
