Motor swap
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=49562
Author:  leftback [ Fri Jan 24, 2014 1:58 pm ]
Post subject:  Motor swap
Could i swap motors on a 9 hp longtail to like a 13 harbor freight on the same frame?
Author:  Trousertrout [ Fri Jan 24, 2014 2:08 pm ]
Post subject:  Re: Motor swap
If the motor lines up sure. Don't know if you are concerned about the frame holding up due to the hp difference. Should be fine
Author:  leftback [ Fri Jan 24, 2014 2:31 pm ]
So really if everything lines up and strength of frame/ motor plate is fine then I should be good
Author:  Trousertrout [ Fri Jan 24, 2014 2:33 pm ]
Yep
Author:  leftback [ Fri Jan 24, 2014 2:35 pm ]
10-4 Preciate it trout
Author:  huck Finn [ Fri Jan 24, 2014 4:00 pm ]
Yes , should be the same up to 16 hp , I have swapped before from 9-16. .
H Finn
Author:  Birddog33 [ Thu Mar 06, 2014 8:35 pm ]
I swapped an 11 Honda for a 13 Honda on devil. Called go devil first though.
Author:  cdc0019 [ Mon Mar 17, 2014 9:34 am ]
23 hp go devil long tail. 12 hrs. Wanting to swap for 35 or possibly bigger surface drive with under 125 hrs
Call me if interested. 678-346-5689
Thanks
Thanks
Author:  cdc0019 [ Mon Mar 17, 2014 9:36 am ]
Thanks
Author:  cdc0019 [ Wed Mar 19, 2014 6:53 pm ]
mine is a 27hp kohler. not 23. see above messages for everything else. thanks
