It is currently Tue Jun 24, 2025 10:30 pm
Reply to topic  [ 9 posts ]
 Cutting transom
Post Cutting transom
Iv got a welder that can weld aluminum so I thought about modifying my boat. Iv got a 1752 flattbottom with 27 mudbuddy longtail siting on a 23 inch transom. It pushes around 15-16 with 2 people but fights like hell to keep in water . If I adjusted trailering edge it goes around 14 but isn't as hard to keep in water . What would yall do cut and lower
Fri Oct 16, 2015 5:01 pm
Post Re: Cutting transom
23??? That is like a super transom?
"Low" is 15-16 and "tall" is usually 20
You can def cut it down but strength of it will depend how far the main bulk of it extends
Sat Oct 17, 2015 6:14 am
Yep guy I bought it off of fished ms river and I think had a 90 hp jet on it it's nice it's that high bc no water swamps in if you let off but n is like little better performance. Iv got the thick hull aluminum so it's a real heavy boat anyway . I'm just trying to figure if it's worth cutting or just leaving it alone I love the boat hat to go hacking on it to only gain 1-2 hp. What yall think
Sat Oct 17, 2015 6:28 am
Sat Oct 17, 2015 6:36 am
Looks like a 2" piece of tubing was added.
Should be able to cut it off and use the existing gussets.
But if you want to cut it down to a short transom I would leave the gussets where they are and taper down to a 8" or so wide spot where your motor mounts and brace accordingly.
And when you cut it down your motor is probably not going to swing back in the boat.
Sat Oct 17, 2015 8:36 am
Sat Oct 17, 2015 9:03 am
If it was mine I wouldn't cut it. I like a tall transom.
I would change the angle of the cavitation plate so that the trim tab would not be needed. I found on my MB the tab caused a lot of drag. The cavitation plate kit from Backwater would work good too.
Nice looking boat.
Sun Oct 18, 2015 4:44 pm
Thanks .... I got looki ng today and the guy I bought it from built the transom up from a 20 in to a 22 1/3 inch transom . But when he did it one side it higher than the other the the transom is not level from one side to the other . So now I'm contemplating cutting it down to a 20 inch that way it's all level and I should be able to adjust it better than I can currently . But it seems like a whole Lotta work especially if it won't make a difference between 22 vs 20 inches . But I'm thinking il get better performance if it's level across the transom in stead of one side being slightly higher .?
Sun Oct 18, 2015 5:46 pm
Users browsing this forum: No registered users and 43 guests
