It is currently Thu Jul 17, 2025 7:13 am
[ 6 posts ] |
Newbie with a question about the Brass bushing
turnquij
Now that I am a mud motor owner and was turned on to this site from another forum board here is my first question to the site. I have an older model beavertail with the brass bushing in the bottom end, when should this be replaced and how difficult is it to replace?
Thanks,
Fri Oct 02, 2009 4:40 pm |
WBG444
Joined: Wed Sep 30, 2009 7:54 am Posts: 112 Location: Mineola Texas!
 Re: Newbie with a question about the Brass bushing
Well u need to pull the shaft out of da housing…and take a look at da bushing…if its wallowed out or worn down really bad on one side…or is no longer there…u need to replace it…before u go and do dat… after da motor has been running a few minutes…kill da motor and feel around dat hub down dare and see if it HOT…I bet your little Bushing is ok…are u using lots of grease…grab da prop and hold da tail and try to wiggle them in opposite directions…is there lots of play
16X60GD 27HP Surface Drive
Fri Oct 02, 2009 5:18 pm |
turnquij
Really this is a legitimate question I could use some help.
There is about a 1/16th inch of play either way, is this to much or will it be ok for the season?
Sun Oct 04, 2009 5:59 am |
JpEater
Joined: Tue Sep 22, 2009 8:02 pm Posts: 245 Location: Augusta, Ga.
1/16" should be ok. some play is normal IMO. Excessive play would be pretty obvious. Keep it greased and keep on truckin. I like the Green Grease. Synthetic, EP rated and Water Proof to boot.
Trey
_________________ Aucoin 18'x48'' Bateau, 30hp GD Longtail.
Sun Oct 04, 2009 6:05 am |
WBG444
Just keep it greased, you’re ok.
Sun Oct 04, 2009 8:44 am |
turnquij
Thanks guys I appreciate your input
Sun Oct 04, 2009 6:52 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 58 guests |
