Quack
 1642 what size motor?
I have a 1642 flatbottom and want to put a longtail on it. I have never been around a mud motor before. What size motor should i put on it?
Sun Mar 02, 2014 7:30 pm |
OlSchool
Joined: Sun Jan 06, 2013 4:24 pm Posts: 384 Location: Louisiana
 Re: 1642 what size motor?
23 longtail does well on 16x42.
Sun Mar 02, 2014 7:36 pm |
BERNIE255
Joined: Sun Jun 16, 2013 4:43 pm Posts: 1381 Location: Avoyelles Parish/ Marksville LA
23 backwater
Sun Mar 02, 2014 7:48 pm |
Quack
I was back and forth between wanting a SD or a LT. I only run maybe a mile and half tops. After some research it looked like SD were more needed when running long distances. Also the boat does not have a grab bar for stand up motoring.
Should I go with something other then a LT. Is a grab bar really needed for a LT?
Sun Mar 02, 2014 8:01 pm |
Quack
I have, I only run about a mile and a half tops. Would a SD be better?
Sun Mar 02, 2014 8:07 pm |
Honky Kong
Joined: Fri Feb 22, 2013 3:41 pm Posts: 227 Location: Mankato, MN
You don't have to have a grab bar to run a longtail. Just have to use a little caution if standing. That said, you don't have to be standing to run a longtail either. Take a look at the 23 HP swomp from back water inc. Best longtail out there right now. Contrary to many peoples beliefs, they are smooth as silk to run. With a light load you could prob get close to 20 mph with one on that boat.
_________________ Backwater Swomp 23 / Lowe L1448M
Mon Mar 03, 2014 10:52 am |
Trousertrout
Joined: Tue Oct 18, 2011 3:18 pm Posts: 1060 Location: Ohio-The land of few ducks
Go backh20 and save a few thousand from going with a SD. Plus you will save money from repairs. No brainer with those short distances.
_________________ 23 swomp/ 1542 tracker
Mon Mar 03, 2014 12:11 pm |
Quack
Thanks for the info
Mon Mar 03, 2014 1:50 pm |
Broadriverboy
I drive my 23 hp gdlt sitting down 90% of the time without a grab bar. You do have to be careful, damn thing has had me puckered up a few times from almost throwing me out.
Mon Mar 03, 2014 2:53 pm |
