Go-devil problem
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=51257
Author:  Mike J [ Sat Mar 08, 2014 9:29 pm ]
Post subject:  Go-devil problem
I have a 16hp go-devil longtail and lately it's been stalling after a few minutes of cruising. It runs fine out of water but when it's got a load on it it stalls. I run it multiple times per week and I run sea foam through it every 3-4 tanks. The carb was cleaned about six months ago. It also has new spark plugs in it. Any advice would be appreciated
Author:  RootSumn [ Sat Mar 08, 2014 10:12 pm ]
Post subject:  Re: Go-devil problem
Had that happen on my old LT and it was a coil pack breaking down.
Author:  bigticket [ Wed Mar 12, 2014 8:37 pm ]
i just had my kill switch diode wire that runs between the coils go bad, dam thing was grounding out my coil even tho the diode was burned in two.
Author:  kibb [ Wed Mar 12, 2014 8:58 pm ]
We've got the same problem on a 16 at work
Author:  BrownDog20886 [ Sat Mar 29, 2014 8:20 am ]
Saw this a bit down the list and was curious about the outcome. Hope you got it figured out already.
Mine was doing a similar thing. It was a fuel starvation issue due to an overly restrictive fuel bulb (fancy one from BassPro). Once I replaced it with a regular Atwood fuel bulb from Walmart, my motor runs like a champ.
This is another possible cause if you've recently switched out some fuel line components.
Nate
Author:  Mike J [ Sat Mar 29, 2014 8:58 am ]
Nate, it turned out to be water in the gas tank. Got the tank and carburetor cleaned out and it runs great now
Author:  BrownDog20886 [ Sat Mar 29, 2014 9:28 am ]
Glad to hear that.
Nate
