U joint grease shroud?
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=51382
Author:  Davis.day [ Wed Mar 12, 2014 4:43 pm ]
Post subject:  U joint grease shroud?
Does anyone know where U-joint grease shrouds for go devils or similar long tails are sold? I cannot find these anywhere for the life of me. I want one to keep the grease from slinging on my transom. Yes I know I may keep over-greasing these joints but it keeps happening. I have seen a few on here a couple were aluminium the other was a camo neoprene one wrapped around.
Author:  North LA Hunter [ Tue Mar 18, 2014 6:36 pm ]
Post subject:  Re: U joint grease shroud?
Beavertail had camo fabric that went across for a shield. And had Velcro on it for easy access to u-joint. You could probably build it yourself.
Author:  OlSchool [ Tue Mar 18, 2014 7:37 pm ]
My u-joint doesn't throw much grease at all. The bearings on the u-joint actually have little seals on them. Either you have different u-joint or yours has bad seals.
Author:  WhoDat88 [ Tue Mar 18, 2014 7:38 pm ]
Author:  SETx Longtail [ Tue Mar 18, 2014 10:12 pm ]
Or any driveshaft shop that's worth a damn...
Author:  Davis.day [ Sun Mar 23, 2014 5:39 pm ]
Yeah only problem is I am in South Georgia. Not many mud motor dealers located anywhere around here. My seals might be bad they dont scream or anything just when I pump grease sometimes I over pump and excess comes out around the seals.
Author:  Walkers Bay Synd [ Sun Mar 23, 2014 5:58 pm ]
Get a neoprene beer can cooler and cut the end tie on with 2 cable ties.
Author:  coupe1975 [ Sun Mar 23, 2014 6:07 pm ]
I'd replace the u joint regardless. Pull it out and take it to a Parts house or driveline shop and match it up.
Also I use to have a homemade beavertail style longtail and had a canvas tarp material shield on it. Had eyelets in it and secured with zip ties.
Author:  Davis.day [ Wed Apr 02, 2014 7:03 pm ]
Thanks that helped a lot
