It is currently Sun Jun 29, 2025 10:02 pm
Reply to topic  [ 7 posts ]
 Go-devil problem
Post Go-devil problem
I have a 16hp go-devil longtail and lately it's been stalling after a few minutes of cruising. It runs fine out of water but when it's got a load on it it stalls. I run it multiple times per week and I run sea foam through it every 3-4 tanks. The carb was cleaned about six months ago. It also has new spark plugs in it. Any advice would be appreciated
Sat Mar 08, 2014 9:29 pm
Post Re: Go-devil problem
Had that happen on my old LT and it was a coil pack breaking down.
1654 Grizzly
'13 35 GDSD
- My Wife
Sat Mar 08, 2014 10:12 pm
i just had my kill switch diode wire that runs between the coils go bad, dam thing was grounding out my coil even tho the diode was burned in two.
1654 GDSD 37efi.
Wed Mar 12, 2014 8:37 pm
We've got the same problem on a 16 at work
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Wed Mar 12, 2014 8:58 pm
Saw this a bit down the list and was curious about the outcome. Hope you got it figured out already.
Mine was doing a similar thing. It was a fuel starvation issue due to an overly restrictive fuel bulb (fancy one from BassPro). Once I replaced it with a regular Atwood fuel bulb from Walmart, my motor runs like a champ.
This is another possible cause if you've recently switched out some fuel line components.
Nate
Sat Mar 29, 2014 8:20 am
Nate, it turned out to be water in the gas tank. Got the tank and carburetor cleaned out and it runs great now
Sat Mar 29, 2014 8:58 am
Glad to hear that.
Nate
Sat Mar 29, 2014 9:28 am
Users browsing this forum: No registered users and 45 guests
