It is currently Mon Jun 30, 2025 9:25 am
Reply to topic  [ 9 posts ]
 U joint grease shroud?
Post U joint grease shroud?
Does anyone know where U-joint grease shrouds for go devils or similar long tails are sold? I cannot find these anywhere for the life of me. I want one to keep the grease from slinging on my transom. Yes I know I may keep over-greasing these joints but it keeps happening. I have seen a few on here a couple were aluminium the other was a camo neoprene one wrapped around.
Wed Mar 12, 2014 4:43 pm
Post Re: U joint grease shroud?
Beavertail had camo fabric that went across for a shield. And had Velcro on it for easy access to u-joint. You could probably build it yourself.
Tue Mar 18, 2014 6:36 pm
My u-joint doesn't throw much grease at all. The bearings on the u-joint actually have little seals on them. Either you have different u-joint or yours has bad seals.
Tue Mar 18, 2014 7:37 pm
40HP Gatortail
Tue Mar 18, 2014 7:38 pm
Or any driveshaft shop that's worth a damn...
-Custom pool noodle
-stage 4 water wings
Tue Mar 18, 2014 10:12 pm
Yeah only problem is I am in South Georgia. Not many mud motor dealers located anywhere around here. My seals might be bad they dont scream or anything just when I pump grease sometimes I over pump and excess comes out around the seals.
Sun Mar 23, 2014 5:39 pm
Get a neoprene beer can cooler and cut the end tie on with 2 cable ties.
Quote:
We had a lot of hunters from down under. All a bunch of great guys that liked to drink, root, and shoot shit in the dark. My kind of people.
Sun Mar 23, 2014 5:58 pm
MMT Eternal Member - Rest In Peace
I'd replace the u joint regardless. Pull it out and take it to a Parts house or driveline shop and match it up.
Also I use to have a homemade beavertail style longtail and had a canvas tarp material shield on it. Had eyelets in it and secured with zip ties.
Sun Mar 23, 2014 6:07 pm
Thanks that helped a lot
Wed Apr 02, 2014 7:03 pm
Users browsing this forum: No registered users and 44 guests
