Need help learning how to drive this beast!!!! https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=52094 |
Author: | Reraylinehand [ Sat Apr 05, 2014 11:33 am ] |
Post subject: | Need help learning how to drive this beast!!!! |
Hey guys, new to the forum and need to pick your brains. Never owned/operated a longtail before and need some help. Is it a common problem for the motor wanting to buck out of the water at 1/4-3/4 throttle? If it is is there a cure or just nature of the beast? And do you need to adjust and set the tilt set bolt before using the motor?. Rig is a 1756 g3 and motor is a marsh monster 35 hp. |
Author: | JLACOUR [ Sat Apr 05, 2014 12:10 pm ] |
Post subject: | Re: Need help learning how to drive this beast!!!! |
Why not call the manufacturer? |
Author: | Reraylinehand [ Sat Apr 05, 2014 12:30 pm ] |
Waiting on call back. |
Author: | txmudcutter [ Sat Apr 05, 2014 12:32 pm ] |
assuming this is a longtail bend the trailing edge of the cav plate up slightly with a big cresent. Do it a little at a time until it rides just below the surface. also a little bending goes a long way |
Author: | Reraylinehand [ Sat Apr 05, 2014 12:47 pm ] |
Thanks tx. I'll give it a try. |
Author: | SETx Longtail [ Sat Apr 05, 2014 1:14 pm ] |
Not familiar with their frames but adjusting your cavitation plate will solve the issue of coming out of water. Post a pic of it and your trim bolt. Should be a nice setup with a 35 on that big hull! |
Author: | Reraylinehand [ Sat Apr 05, 2014 2:03 pm ] |
Here ya go |
Author: | flatontheplatte [ Sat Apr 05, 2014 3:38 pm ] |
Angle of that cav plate looks weird, on my GDLT the plate is much closer to the prop. Regardless bending that plate should fix your issue. |
Author: | Randy S [ Sat Apr 05, 2014 4:21 pm ] |
Author: | Reraylinehand [ Sat Apr 05, 2014 7:00 pm ] |
I see the angle. Idk why the plate would b so far away from the prop. And new to mud motors so is the an advantage/disadvantage to it? |
Author: | SETx Longtail [ Sat Apr 05, 2014 7:39 pm ] |
The cavitation plate keeps the prop at a specified depth when running. You ideally want the top of the plate 2-3" under the surface when on plane running wide open. I can see mine under the surface when running. These are NOT surface piercing props like on the surface drives. They must be completely submerged in clean water to work properly. If you are getting air bubbles in the water before the prop it will also cause it to come out of the water. Next time I'm out I'll try to get you a video. I was out today. If I had checked this I would have done it then.... |
Author: | coupe1975 [ Sat Apr 05, 2014 7:49 pm ] |
Author: | SETx Longtail [ Sat Apr 05, 2014 7:50 pm ] |
I am ![]() ![]() |
Author: | coupe1975 [ Sat Apr 05, 2014 9:49 pm ] |
I've done similar. When I had my air boat I pulled it to lake ****** in the northeast Dallas area with my 2½ ton service truck. The looks I got from people passing me. Like its alittle overkill isn't it? One guy ask at a gas station why such a big truck to tow that boat? Told him I was going to use the Crane on the truck to get the Gators out of the boat at the ramp ![]() |
Author: | SETx Longtail [ Sat Apr 05, 2014 10:01 pm ] |
I may or may not have used mine to take the boat off the trailer to replace my boards.... Lol |
Author: | stu [ Thu Apr 10, 2014 8:21 am ] |
Author: | coupe1975 [ Thu Apr 10, 2014 9:24 am ] |
Why not Ben? I used mine to lift boat to apply the GatorGlide |
Author: | Reraylinehand [ Sat Apr 12, 2014 9:33 am ] |
Love the rigging!.. just bent it yesterday getting rain so hopefully try it tomorrow |
Author: | Reraylinehand [ Sun Apr 13, 2014 12:22 pm ] |
Gotta thank you guys! Run awsome never bucked once! Plus caught some cats for dinner. Thanks for the tips[list=][/list] |
