29hp mud buddy?
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=53265
Author:  Crash99 [ Thu May 15, 2014 6:32 pm ]
Post subject:  29hp mud buddy?
Hi I'm new to MMT, been reading and learning a lot as I've never owned a mm but will be buying in the near future. I have a 14x42 Jon boat and just found a mud buddy 29 hp Kawasaki and was wondering if that is to big for my boat and if it's a good mm
Author:  Russ [ Fri May 16, 2014 6:10 am ]
Post subject:  Re: 29hp mud buddy?
Its a good mm. Itll work but its alot of motor for that boat. That will get you out of pretty much anything it gets you into. just be careful.
Author:  DeltaRunner [ Fri May 16, 2014 6:55 am ]
My buddy has one on a 1554 Jon. Tac read 2,200 when he bought it. That was 8 years ago. He can go just about anywhere he wants.
Good motor for sure.
Author:  BERNIE255 [ Fri May 16, 2014 9:58 am ]
It will be ok, just beef up that transom and put some splash guards so you dont swamp
Author:  Crash99 [ Fri May 16, 2014 11:56 am ]
Thanks for the replies, I mostly trap from my boat so I carry a lot of weight already with that considered am i pushing my luck quite a bit?
Author:  BoatDR [ Fri May 16, 2014 12:15 pm ]
I ran one on back of a 1440 I had. I had to build a box behind the front deck to house the battery and gas tank, becuase with either one of them in the rear the stern squatted too bad. Once I moved some weight to the front of the boat she ran like a champ.
Author:  BERNIE255 [ Fri May 16, 2014 3:24 pm ]
Just distribute the heavy stuff to the front and middle so it sits even, and dont let of too fast
Author:  Crash99 [ Sat May 17, 2014 12:00 pm ]
Thanks I think it might be a bit much for my boat, I'll just keep saving for a backwater 23hp
Author:  Russ [ Sat May 17, 2014 12:08 pm ]
Whered u find that 29, and how much?
Author:  BERNIE255 [ Sat May 17, 2014 1:23 pm ]
wwhat is the brand of the boat?
Author:  Crash99 [ Sat May 17, 2014 1:32 pm ]
I found it on trapperman.com $2000 located on south central Iowa, it's 4 pages deep in the trap shed titled mudd motor, my boat is a alumacraft and I load it extremely heavy during season so I think I better just go with a smaller one, I talked to back water n will prolly go that route
Author:  BERNIE255 [ Sat May 17, 2014 2:10 pm ]
why not try and find you a larger boat so you have more room?
Author:  Crash99 [ Sat May 17, 2014 3:21 pm ]
Most of my loading and unloading is done in a inch or less of water with a bit of dragging, had a 16x48 but it was real tough to drag n load n unload, love my 14' just need a mm
Author:  Honky Kong [ Mon May 19, 2014 9:45 pm ]
Back Water is the way to go. I have a 23 Swomp on a 1448 and it's a sweet combo. Run your gas tank or battery up front and you will have a sweet setup.
Author:  darrel from meraux [ Mon May 19, 2014 10:13 pm ]
They got a 29 Kawi mb sd on local forums for 1700 right now if anyone's still lookin. If I recall correctly they are already fuel injected strong motors
Author:  Russ [ Mon May 19, 2014 10:51 pm ]
They are nice. And yes, the 29s have fi.
Author:  crawfordw2 [ Fri May 23, 2014 8:10 am ]
I had a 23 hp mudbuddy on a 14x42 jon boat and it was the perfect setup until I squared a stump up just right. Boat got a hole the size of your fist. Good thing I was close to the bank. Other than that I loved that combo.
