It is currently Mon Jun 30, 2025 1:28 pm
Reply to topic  [ 7 posts ]
 20 honda
Post 20 honda
What model fuel pump is on these engines? Jus picked me up a motor for my long tail frame.
18' Aucoins Skiff w/ 35 GTR
Wed May 21, 2014 7:13 pm
Post Re: 20 honda
Facet is usually what comes on them
Any 3.5 psi electric fuel pump will work
Wed May 21, 2014 9:46 pm
Post Re: 20 honda
Are you referring to the pulse pump on the engine itself?
Thu May 22, 2014 4:51 pm
Post Re: 20 honda
I replaced the fuel pump on my Honda 20 HP GD a while back but don't remember the exact specs. Mine is an older engine and the pump is vacuum driven. The small engine guy had both the Honda OME fuel pump and an equivalent Briggs fuel pump in stock. He told me they are simple little diaphragm pumps and are interchangeable. The Briggs was $7-8 if I remember properly while the Honda was much, much more expensive. They are both black plastic and the bolt pattern and hose nipples are the same, so I tried the Briggs. My motor runs well with it.
Nate
Thu May 22, 2014 6:16 pm
Post Re: 20 honda
It's the electric pump mount on frame. Thanks guys.
Fri May 30, 2014 1:02 pm
Post Re: 20 honda
It's wise to shit can the pulse pumps if you have them , they don't have enough draw to
Pull the gas up the fuel hose from the tank most of the time.
Fri May 30, 2014 8:25 pm
Post Re: 20 honda
Fri May 30, 2014 9:17 pm
Users browsing this forum: No registered users and 43 guests
