| MudmotorTalk.com https://www.mudmotortalk.com/mmt_v2/ |
| Advantage, Bog Hog, Swomp, mudmotors https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=53512 |
| Author: | bojac [ Mon May 26, 2014 9:05 am ] |
| Post subject: | Advantage, Bog Hog, Swomp, mudmotors |
Hey! Anybody tried the heavy duty version of the Advantage mudmotor? I'm looking for a good U-weldit kit. How about the Backwater SWOMP kit? For 16hp+ motors. Give me some knowledge guys! |
| Author: | huck Finn [ Mon May 26, 2014 10:05 am ] |
| Post subject: | Re: Advantage, Bog Hog, Swomp, mudmotors |
Swomp from back h20 , no comparison , I have one , and really like it . H finn |
| Author: | SETx Longtail [ Mon May 26, 2014 10:35 am ] |
Get a back water glider kit if you want to put one together yourself. They have engineering and options that are far far ahead of the rest of the Longtail pack... |
| Author: | bojac [ Tue May 27, 2014 6:13 am ] |
That Advantage frame looks pretty beefy. |
| Author: | jarnotski [ Wed May 28, 2014 11:43 am ] |
What is the biggest engine you can use with a Glider kit? For some reason I thought a 16 would work with the glider kits. |
| Author: | FRANKtheTAU [ Wed May 28, 2014 2:17 pm ] |
I've been told several people are running 16hp Honda clones with the SWOMP lite glider kit. You can also get the bigger frames as a glider kit and run 35 Briggs. Just call the guys at Back water and let them know what you're wanting to do. They'll take care of you. |
| Author: | bojac [ Thu May 29, 2014 5:30 am ] |
The Glider lite kit looks good. Except I'd be skeered a taking it through anything tough. It has no spine or bracing for the shaft tube. |
| Author: | bojac [ Thu May 29, 2014 10:12 am ] |
OK! I talked to Jake at Backh2o. A heavier duty Glider kit is coming out later this summer. The bigger motors like 16 + will bolt right up. And it will have a stiffener spine on the shaft tube. Right now the frame mount has to be modified on the 10+ Glider kit to fit a 16hp. And h2o would do it for a customer. Heck! I'm gonna wait for the new Kit. It'll be around $1,500. |
| Author: | 139sst [ Tue Jun 03, 2014 5:07 pm ] |
Huck finn, what is the most noticeable difference between the backh20 and the godevil. Is there anything you like better about the godevil? What about grinding out with the shorter shaft? Thanks |
| Author: | jstauber [ Tue Jun 17, 2014 7:24 am ] |
I had the bog hog u weld kit and i ran that with a briggs 16hp vanguard and i liked it but it was slow on my tracker so i bout the 23hp godevil and i love that! |
| Author: | bojac [ Fri Jun 27, 2014 6:18 am ] |
I just ordered the Bog Hog U weldit kit. I should of waited for the new Hd Glider Lite from Backwater that will be coming out, but I want to put one together from scratch. I'm going to beef up the frame alittle like the GD, MB, etc. I was thinking about attaching a rollerbearing housing on the lower part of the shaft tube, but not sure how to go about it. Also someone mentioned that bushings were easier to change? I have a 16hp Briggs to put on it. The frame will take up to a 30hp. |
| Author: | backwater86 [ Sat Jul 05, 2014 3:46 pm ] |
BackH2O will sell u bearing case sets that will retro to most longtails . Easy install for anyone with some skill with welder. |
| Author: | bojac [ Sat Jul 05, 2014 4:27 pm ] |
Great! Thanks for the information 86. I was looking at beavertail parts and they screw on. left hand threads on the bottom. That's out. I'll check H20. |
| Author: | backwater86 [ Sat Jul 05, 2014 7:26 pm ] |
Pretty much the same but better. Ive owned B.W. motors for 5 years and havent had a seal or bearing issue yet. |
| Author: | bojac [ Sat Jul 12, 2014 5:48 pm ] |
I got 'em ordered. |
| Author: | huntnmudman [ Tue Dec 30, 2014 7:46 am ] |
Check out the New Mud motor by Advantage the design its as tuff as it is beefy. I bought a HD kit over the summer. You cant go wrong if you want strong. www.advantagemudmotors.com |
| Author: | FRANKtheTAU [ Tue Dec 30, 2014 9:42 pm ] |
