| MudmotorTalk.com https://www.mudmotortalk.com/mmt_v2/ |
| Generac 33 hp and SWOMP kit https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=55873 |
| Author: | Goody032 [ Tue Aug 19, 2014 11:40 am ] |
| Post subject: | Generac 33 hp and SWOMP kit |
Will a generac 33hp work with the SWOMP kit. Just wondering if it will handle the higher hp motor and also how the tapered shaft would work. I'm new with this mud motor stuff so any input would be nice. |
| Author: | FRANKtheTAU [ Tue Aug 19, 2014 6:05 pm ] |
| Post subject: | Re: Generac 33 hp and SWOMP kit |
Power731 on here ran a 33 Generac on a 35hp SWOMP frame. |
| Author: | tmetz [ Thu Sep 04, 2014 7:24 am ] |
| Author: | Apex [ Sun Oct 12, 2014 9:38 pm ] |
What sleeve is this that turns the tapered shaft into a straight shaft? thanks |
| Author: | brlcla [ Fri Jan 30, 2015 12:14 am ] |
| Author: | Glades Ranger [ Fri Jan 30, 2015 7:14 am ] |
Tommy, what kind of numbers are you getting with the Generac 33? MB had them for a short while but I've never read any reviews from the field. I have to overhaul my 27 HP before next season...have to budget for a swomp. |
| Author: | Schmidty721 [ Thu Feb 05, 2015 2:49 pm ] |
Is this the engine you guys have used? http://www.brandnewengines.com/0H0684.aspx No issue's with being a fixed speed generator engine? Ie, easy to hook up a throttle cable? |
| Author: | brlcla [ Fri Feb 06, 2015 4:00 pm ] |
Almost every industrial vtwin engine is designed to run fixed apeed 3600+/- all day long. But dont buy that one it has a tapered shaft. You need to look for a 0054420srv model. Its got 1-7/16 shaft but 1-1/8 shafts part # 0E4357G are easy to find and is a direct swap. Guess you could buy the taper shaft and swap also. Here this website can save you a few hundred dollars also. http://www.m-and-d.com/GEN-0054420SRV.html |
| Author: | Schmidty721 [ Fri Feb 06, 2015 4:53 pm ] |
| Author: | brlcla [ Fri Feb 06, 2015 10:52 pm ] |
Since this is longtail talk yep im sure you can get a u-joint that is 1-7/16 x "x" pending your drive shaft diameter. That should be easy. |
