It is currently Tue Dec 23, 2025 6:31 pm
[ 7 posts ] |
Bdub2
 Go devil issue
I have a 9hp Briggs long tail. Wanna say its a late 90's model. Ran perfect last winter, let it sit all summer and got rust in gas tank. I replaced gas tank and fuel filter and fuel lines. Also changed oil. Motor runs great while sitting level. But when I lower the prop below level the motor runs for about 30 seconds and shuts off. If I keep motor close to level it runs great in water or air but in water it's a struggle to keep it high enough. I checked to make sure there is enough oil. I took the carb bowl off and sprayed SEAFOAM all over inside of carb and around float. Gas runs through carb when tilted back. I have no idea what the deal is. Like I said I can run motor at full throttle in water I just have to keep motor as level as possible or it will shut off. And will start on first try.
| Sat Aug 23, 2014 10:02 pm |
Pumpgunner
Joined: Sat May 08, 2010 12:22 pm Posts: 22 Location: 15 minutes from Idaho, an hour from Wyoming
 Re: Go devil issue
Is your carb float sticking? Just an idea.
| Mon Aug 25, 2014 10:50 pm |
Randy S
Joined: Sun Oct 02, 2011 4:03 pm Posts: 313 Location: NELA
 Re: Go devil issue
Is it an electric start model? Those were equipped with a mercury tilt switch; a misadjusted one could be the source of your trouble.
| Tue Aug 26, 2014 8:55 pm |
Bdub2
 Re: Go devil issue
Yes it is. But I took the tilt switch off of the motor, it looked burnt out. I thought that only affected the ability to start motor. Who that shut my motor off during use
| Wed Aug 27, 2014 6:10 pm |
Randy S
 Re: Go devil issue
You're right, tilt switch should only impact the start circuit. One other thought is the low oil level cutoff. I think it's normally open, so you should be able to unplug it and test the impact.
| Thu Aug 28, 2014 8:01 pm |
ds541
 Re: Go devil issue
I also think it's the low oil cut off, just unplug it and see it it helps. if that's the problem they are easy to change and don't cost much.
| Thu Aug 28, 2014 9:26 pm |
Bdub2
 Re: Go devil issue
What's the low oil lvl cut off look like? My motor is a 97
| Sat Aug 30, 2014 9:13 pm |
[ 7 posts ] |
