Gas line hook-up https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=56423 |
Author: | BrownLab [ Mon Sep 08, 2014 11:24 am ] |
Post subject: | Gas line hook-up |
I bought a used Mudbuddy last year and need to replace the fuel lines. It's a Kawasaki 29 HP longtail. What's the best way to connect the gas lines to the tank? I looked at the local boat stores and they only had connectors for outboards. Need the fuel line and vent connection. Unfortunately, I was unable to use the motor or the new boat I bought it for after breaking my leg just two days after the purchase ![]() Thanks in advance for the help!! |
Author: | bbb [ Mon Sep 08, 2014 11:30 am ] |
Any quick connect works as long as you buy the male and female of that brand. I think mine are Johnson/evinrude connections. Most don't like the quick connects and just hook the fuel line into a open brass connection. This is the connection I use I will say that the little rubber O ring in the above fuel line connection has a tendency to dry rot every few years. I carry a couple extras in my boat. |
Author: | BrownLab [ Tue Sep 09, 2014 10:58 am ] |
Post subject: | Re: Gas line hook-up |
What do you do about the return line to the tank from the fuel pressure regulator? Is there a dual line connector for the tank that will have both the supply and return? Or do I need two connection fittings on the tank? |
