It is currently Tue Dec 23, 2025 11:38 am
Reply to topic  [ 6 posts ]
 MBLT parts
Post MBLT parts
Looks like I smacked the cement under the water at the boat ramp and bent my shaft. The prop needs to be replaced anyway. I'm going to go ahead and replace bearings and seals along with the shaft and new prop.
Is there anywhere besides Utah to get these parts? I really don't feel like waiting a week for a call back or return email. I know I'm small beans on their radar and that's fine. I just don't want to deal with them.
Thu Oct 02, 2014 5:33 pm
Post Re: MBLT parts
I would give Boat Dr a call. He probably has what you need or could get it pretty fast.
Fri Oct 03, 2014 7:00 am
Post Re: MBLT parts
Check out backH2o they have sealed upper and lower bearing system, pricey though. I emailed them the other day and asked how involved it would be to add their system to my 23 HP GD..
"Yes you can make that bearing system work on your motor. Because the
bearing are not inside your drive tube the drive tub has to be shortened
on the bottom end. Call or write with any questions."
16' skiff 23 GDLT
Sat Oct 04, 2014 12:16 am
Post Re: MBLT parts
Locate Ball Bearings 1 800 409 3632. Just order 2 sets of bearings and seals. SICK of the runaround in UTAH. They can't get a order right to save there life. And this is after I order 3 times and a 1000.00 dollars later. These guys saved me a ton of money 2 upper bearings,2 upper seals, and 2 lower bearings 73.86 to my front door.Now I have extra when I break shit.Hope this helps.
Tue Oct 14, 2014 7:37 pm
Post Re: MBLT parts
Can you order the bottom collar cap from them? My shaft came loose and rode up the tube and messed up the cap plus the lower seals and bearings in my motor. Also do you know what the part numbers would be for a 05 mud buddy long tail 25hp?
Wed Oct 15, 2014 9:43 am
Post Re: MBLT parts
Collar cap mud buddy.The only seals they didn't have were the lower seals.I'am waiting on another company to call me back. If they have them I will post the name and number. As far as what fits your motor I'am not sure mabey someone knows who has your year and H.P. I have a 35 mb 2010. But if you have a local mud motor dealer support them.
Thu Oct 16, 2014 11:43 am
