24hp beavertail u joint
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=57679
Author:  Josh2000ford [ Thu Oct 30, 2014 11:32 am ]
Post subject:  24hp beavertail u joint
I am looking for a part number or something I can cross reference for the size of the u joint used on a 2000 24 honda beavertail. Tried contacting beavertail with no reply. Just looking to save time pulling and running around town
Thanks
Josh
Author:  butternut [ Tue Nov 04, 2014 2:08 pm ]
Post subject:  Re: 24hp beavertail u joint
Huck finn can you help this guy?
Author:  wing dam [ Thu Nov 06, 2014 3:59 pm ]
These are the part #'s from Beavertail.
94120 U-Joint,
3/4" for 6 Hp
94140 U-Joint
1" for 13 HP
94130 U-Joint
1 1/8" for 20-
35 HP
If you call them they will usually answer. I think the 94130 is around $80 from them.
Author:  FRANKtheTAU [ Thu Nov 06, 2014 6:30 pm ]
Pull the U joint and take it to NAPA or another parts house and tell them you need a new one.
Author:  Dnuts054 [ Fri Nov 07, 2014 6:40 am ]
Wing dam is correct. 94130 is the part # you want. I had a 2002 beavertail and that is the one I ordered. The 24hp honda motor has the 1 1/8" diameter shaft. If you want to double check just look up the motor specs online or in the manual
Author:  flatontheplatte [ Fri Nov 07, 2014 8:01 pm ]
You are crazy if you pay $80 for a u joint. $12 at a parts store.
