It is currently Fri Jun 27, 2025 6:39 am
Reply to topic  [ 9 posts ]
 23 swomp vs 23 mb
Post 23 swomp vs 23 mb
Which motor would you guys recommend for my tracker 1448? It will mostly be 2 of us hunting with a small hunting load (close to 400 lbs for all).
Thu Nov 06, 2014 9:42 pm
Post Re: 23 swomp vs 23 mb
Swomp
Thu Nov 06, 2014 9:43 pm
What kind of speeds do yall think I would get? I would go with the short shaft motor
Thu Nov 06, 2014 10:01 pm
What height is your transom , 59" for short transom boats. , ss , 72" for tall transom boat s ,Ls . I run a swomp. 23. ( modded stage II. ) on a. 15 x 36 godevil duck skiff , stock I was running 19-20 . But definitely suggest the backwater over any other longtail .
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Thu Nov 06, 2014 10:06 pm
It's a short transom so I would run the 59
Thu Nov 06, 2014 10:08 pm
Frank the tau ran a stock 23 swomp ss on his war eagle boat and ran same 19-20 range . Longtails typically like long skinny boats , yours would be shorter and wider but speeds should be compareable. , is it a true flat bottom .
H Finn
BACKWATER PROSTAFF
Thu Nov 06, 2014 10:12 pm
No, I have rails on bottom
Thu Nov 06, 2014 10:17 pm
Be similar to franks war eagle . Good luck .
H Finn
BACKWATER PROSTAFF
Thu Nov 06, 2014 10:19 pm
Been there. Done that. Got the T shirt.
You're doing yourself a disservice if you don't go with the SWOMP.
Fri Nov 07, 2014 12:43 am
Users browsing this forum: No registered users and 43 guests
