It is currently Fri Dec 19, 2025 9:40 am
Reply to topic  [ 3 posts ]
 Prop difference?
Post Prop difference?
I am currently running a 9x6 on a 20hp, I see where I'm really supposed to have like a 9x4. Is it really that big of a difference?
Sat Nov 29, 2014 4:46 pm
Post Re: Prop difference?
The extra pitch will cause the engine to work harder to turn the prop. Especially at wot and when loaded and when in a lot of mud or vegetation. The engine won't build as many rpm which will cost you speed. Can lead to early engine wear.
Mon Dec 01, 2014 8:13 am
If you have a tach check your rpms with your average load and underway. That will determine if you are running the correct prop. If they are too low, pitch down, and vise versa
Wed Dec 03, 2014 7:11 pm
