Shippjt3443
 GD dieing
Got a new gdlt 16 couple month ago an been running fine. Took it out the other morning and it would run for about two minutes then choke down. Gas cap was off so couldn't have been that. Any ideas wat should check?
Fri Dec 12, 2014 4:30 pm |
LB200
 Re: GD dieing
Is the squeeze ball collapsing?
Fri Dec 12, 2014 5:04 pm |
45th parallel
 Re: GD dieing
Fuel cap,Fuel filter, fuel tank, check fuel line for leaks or kinks, old/bad gas, dirty carb, ask questions on MMT is the usual order when I have a problem, or drive with the choke on until I can't stand it any longer. Good luck!
_________________ 35 Swomp on a 17-52 Alweld on a crusty old trailer you probably shouldn't follow too close 10hp Swomp lite 14-36 alumacraft
Fri Dec 12, 2014 6:07 pm |
Muddy ducks7
Joined: Thu Jun 05, 2014 3:12 pm Posts: 396 Location: Bama
 Re: GD dieing
Fri Dec 12, 2014 7:29 pm |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
 Re: GD dieing
_________________ so many rivers, so little time
Sat Dec 13, 2014 10:02 am |
Shippjt3443
 Re: GD dieing
yeah the ball is collapsing LB200
Sun Dec 14, 2014 6:49 pm |
cb5331
 Re: GD dieing
Sounds like the line or the pickup is clogged if the bulb collapses.
Sun Dec 14, 2014 6:55 pm |
Shippjt3443
 Re: GD dieing
ill check that out, preciate the help
Sun Dec 14, 2014 6:59 pm |
45th parallel
 Re: GD dieing
I saw a post on here about a year ago about some fuel lines that were shedding their liner like a snake skin and plugging up, just a thought if the bulb is collapsing .
Mon Dec 15, 2014 10:25 pm |
LB200
 Re: GD dieing
Tue Dec 16, 2014 5:30 am |
stualaska
 Re: GD dieing
These guys are correct. If the ball is collapsing there is a restriction between the ball and the tank. Are there any other symptoms you haven't mentioned, like is the battery or the tool box setting on the fuel line? Why was the gas cap off?
Tue Dec 16, 2014 12:28 pm |
Shippjt3443
 Re: GD dieing
thought it needed to be off to vent but yall tell me, know hell of a lot more than I do
Tue Dec 16, 2014 4:51 pm |
stualaska
 Re: GD dieing
Wed Dec 17, 2014 1:46 am |
Shippjt3443
 Re: GD dieing
had to of been it, little bastard was swimming around when I checked it
Wed Dec 17, 2014 5:32 pm |
Gigafowl
 Re: GD dieing
Get now line at auto parts house and pump bulb from academy or wally world....
Use small diameter 3/8" line not larger 5/8" - it works better...
Then give it another try...
Wed Dec 17, 2014 5:39 pm |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
 Re: GD dieing
You should be able to blow back to tank from primer bulb end and it bubble up in tank. Primer bulb should be like a check valve - flow to motor not to tank. I have actually seen Mariner/Mercury fittings at tank not push ball in connector far enough to open/ btw mercury plugged into Yamaha fitting will cause that trouble also --- that is if you are using quick connect fittings. and also those attwood type quick connects are a big piece of shit! Personally I tend to stick with omc type fittings on tanks and hoses, have 3 boats and it makes it easier to move fuel and tanks where needed.
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
Thu Dec 18, 2014 8:45 am |
