| MudmotorTalk.com https://www.mudmotortalk.com/mmt_v2/ |
| 5.5 Briggs build https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=60609 |
| Author: | jdbuckshot [ Fri Mar 06, 2015 9:47 am ] |
| Post subject: | 5.5 Briggs build |
Here is one of two I am working on. I have to build the motor mount and handle. The motor is off an old generator, I pressed out the coupling from the armature and made the coupler. shaft had a 1/4" shear pin @ the coupler. it has bronze bushing and sealed needle bearing on the ends. runs very true with no grease in the shaft. I used some short pieces of 1" ID DOM tubing welded to the ends of 3/4" galv pipe to hold the bearings. ID of the shaft housing pipe is .801 so once filled with grease every thing will be real tight. |
