13 hp backwater bogging down
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=60652
Author:  TFWaterfowlSAV [ Sun Mar 08, 2015 8:32 pm ]
Post subject:  13 hp backwater bogging down
Any help would be awesome.
Once I drop the cav plate down below surface the motor sounds like it's bogging down and stalls out or "dies". Not sure if the predator has a low oil sensor but I am going to test that out tomorrow after reading some similar threads. Specs are below.
Predator 420cc 13-14hp depending on where you read the hp stats
Backwater swomp lite glider kit w, 9x5 prop
15x38 flat bottom lite boat about 250ish
Cav plate seems to ride fine right at surface.
Author:  ajverret [ Mon Mar 09, 2015 5:29 pm ]
Post subject:  Re: 13 hp backwater bogging down
Check ur grounding wire
Author:  Nddatv [ Mon Mar 30, 2015 8:42 pm ]
Turn idle up a lil more. The weight on prop needs a lil more force behind it
Author:  FRANKtheTAU [ Mon Mar 30, 2015 9:52 pm ]
I'll bet you it's the low oil sensor. Start the motor while on the trailer then lower the prop like you were in the water and see if it dies.
