It is currently Wed Jul 16, 2025 12:54 pm
[ 5 posts ] |
Moving Cavitation Plate for a Tall Transom boat?
JpEater
Joined: Tue Sep 22, 2009 8:02 pm Posts: 245 Location: Augusta, Ga.
I am looking at a short transom 27hp longtail for a tall transom boat I am getting. I called GoDevil and they said that I need to cut and re-weld the cavitation plate to make the motor work on a tall transom boat. Anyone know exactly what to do? Only thing I can think of is that the angle of the plate needs to be changed considerably. Anyone done this before?
Thank
Trey
_________________ Aucoin 18'x48'' Bateau, 30hp GD Longtail.
Tue Nov 17, 2009 11:53 am |
tjengle
 Re: Moving Cavitation Plate for a Tall Transom boat?
Yea not too long ago I did the same thing you are needing to do. Pretty easy to do just order the plate kit from go-devil (it is already welded up and ready to go) cut the old off and weld the new one on. The critical part is just having enough space between the prop and the plate when you are done. Just weld the new one on then you can run it in the water and start fine tuning.
Tue Nov 17, 2009 8:57 pm |
JpEater
SO is it a different plate or just the angle of the plate that changes?
Wed Nov 18, 2009 7:14 am |
tjengle
It is a different plate all together already welded to the piece that you weld to the shaft tube....Go-devil has done the hard work for you and already has the angle and everything figured out for you...Call and talk to Waren Coco at go devil he can answer any questions you may have... He is very helpful
Wed Nov 18, 2009 9:48 pm |
Krizzle
Joined: Fri Jul 17, 2009 9:42 pm Posts: 45 Location: MS
I've heard you can adjust the steering bolt(?) on the motor to work with a tall transom boat. I think you just don't have as much reach. Anyone done that?
_________________ 1650 Alumaweld w/a 25 Kohler GDLT
Thu Nov 19, 2009 9:16 am |
[ 5 posts ] |
Users browsing this forum: No registered users and 59 guests |
