It is currently Fri Dec 19, 2025 7:43 pm
[ 9 posts ] |
jonesy16
Joined: Mon May 06, 2013 8:54 pm Posts: 14 Location: East Lansing, Michigan
 Frozen Throttle Cable
When hunting some nasty weather this past year, my throttle cable froze up on my 13hp Backwater. Any suggestions on preventing this next fall? WD40 was all I had on the boat, it was a quick fix, need something that is going to nip this problem in the butt. Thanks!
| Tue Mar 24, 2015 1:51 pm |
baron von
Joined: Tue Jan 21, 2014 2:52 pm Posts: 2806 Location: Minnesota
 Re: Frozen Throttle Cable
pour some heet fuel line de-icer in there to get rid of the moisture, and lube it real good a little dab of silicone on the ends to keep moisture out
_________________ that's going itch when it dries
| Tue Mar 24, 2015 1:55 pm |
brstanle
Joined: Sun Oct 05, 2014 12:27 am Posts: 659 Location: SETX/Houston
WD-40 works pretty well too.
_________________ 35 GTR w/ 1860 GoDevil "Ironsides"
| Tue Mar 24, 2015 1:59 pm |
dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
Quick fix in a pinch: Piss on the cable to warm it up.
Before it gets cold, shoot some silicone or wd40 up both ends of the cable, then seal with grease or Vaseline.
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
| Tue Mar 24, 2015 3:38 pm |
4Cody4
Joined: Thu Mar 31, 2011 11:21 am Posts: 2530 Location: Land of 10,000 Lakes
FYI that when it's actually cold, taking a leak on the line will do nothing but cover your motor in pee icicles.
30 degrees ain't cold. When mine was freezing up it wouldn't thaw out for more than a minute or so and that was using a torch.
_________________ "Two people in this world wear helmets, and that's dare devils and pussies." - Willie Braun
| Tue Mar 24, 2015 3:42 pm |
45th parallel
Moving to Arkansas is the the only sure bet. Squirt the cable housing full of mineral oil from the drug store- yes the laxative-it's also good for reconditioning butcher block, and putting in your buddies beer when he isn't hunting out of the same boat the next morning. There are also extreme cold weather gun lubricants that work, just tell the boys down at the gun shop you're going hunting for polar bears and musk oxen and your worried about your firing pin freezing up, they'll get you fixed up right.
_________________ 35 Swomp on a 17-52 Alweld on a crusty old trailer you probably shouldn't follow too close 10hp Swomp lite 14-36 alumacraft
| Tue Mar 24, 2015 7:19 pm |
brstanle
....... Or you could just use WD-40 and put some grease at the ends.
| Tue Mar 24, 2015 7:35 pm |
SETx Longtail
_________________ #CFFITR
| Tue Mar 24, 2015 7:43 pm |
yellow dog
Silicone spray will keep it from freezing.
Sent from my iPhone using Tapatalk Jim
| Tue Mar 24, 2015 7:44 pm |
[ 9 posts ] |
