finger/ lever throttle
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=63984
Author:  232rm [ Fri Oct 02, 2015 6:04 pm ]
Post subject:  finger/ lever throttle
Wondering if anyone converted the trottle to a lever style(brake lever style). I have a 18hp vanguard and just wondering how to set the carb up to get it to close up when releasing the throttle. Right now it has a pull type lever to whereever you stop the pull thats where the throttle will stay.
Author:  BDUBYA [ Fri Oct 02, 2015 6:22 pm ]
Post subject:  Re: finger/ lever throttle
There not a place you can put a spring that will pull the cable back when you let go of it?
Author:  232rm [ Fri Oct 02, 2015 7:10 pm ]
There may be, i was mainly looking to see if anyone has done it before so i wont have to guess with spring size/tension or if someone sold a bolt on kit more or less.
Author:  huck Finn [ Fri Oct 02, 2015 7:12 pm ]
Author:  Mark F. Cheney [ Sun Oct 04, 2015 7:47 pm ]
first off loosen the Nut that holds the lever that you mentioned on its pivot pin. This will probably solve your spring problems. A bike brake lever and cable and housing shouldn't cost more than $20.00 or so.
Mark F. Cheney
