It is currently Mon Dec 22, 2025 1:35 am
Reply to topic  [ 7 posts ]
 Tiller handle bracket/mount ideas
Post Tiller handle bracket/mount ideas
While hunting today my tiller hand bracket that the tiller slides into cracked and blew out. I used 1-1/8" square tube. Guessing it's 11 ga thick, cracked right down the middle while I was pulling on the tiller, made me fall, break my stern light in half and bout swamped the boat. Any recommendations on how to secure the handle to the motor base plate? I want the handle to be removable still so I can fit it in the garage. The old bracket that the tiller handle slid in had 5/16 G7 bolts holding it in. One bolt went through the handle the other one just screwed down tight against it.
Sun Oct 25, 2015 10:59 am
Post Re: Tiller handle bracket/mount ideas
The pipe for the tiller handle is schedule 40 pipe. Wanna say od is just a hair over 1 inch
Sun Oct 25, 2015 11:02 am
my removable handle or tiller is secured to the motor with a 1/4" by 4" angle that is bolted to the 2 motor mount bolts on one side of the motor base. I have 4" of tubing that is welded to this angle horizontal with the PTO. I mill a flat on this tubing that facilitates positioning on the side of the angle for welding. This tubing is of a size that allows the tiller handle to slide in to it for 4". I then have a cross bolt passed throw both the 4" piece and the tiller handle to hold it in the welded 4" piece. Questions? call me.
Mark F. Cheney
on the Great Salt Lake marsh
Sun Oct 25, 2015 4:20 pm
I'm a noob but I do have shop skills. Pictures would help.
Sun Oct 25, 2015 7:14 pm
I'll put some pics up. I think what I'm going to end up doing is taking 1/4 flat and building a "box" out of that and bolting through the handle.
Mon Oct 26, 2015 6:10 am
I was thinking maybe make a channel with a notch in the end then a bolt thru one end and a hole for a pin thru the other. That way you could rotate the handle 90 degrees for storage but you don't have to take all the way off. Just spitballin.
Mon Oct 26, 2015 9:45 am
Not a bad idea
Mon Oct 26, 2015 10:11 am
