It is currently Sun Jun 22, 2025 3:53 pm
Reply to topic  [ 23 posts ]
 My longtail build.
Post My longtail build.
Building my first longtail using the mad mud motor plans as a guide. 420cc Harbor Freight engine. We started Yesterday for a little bit and today for a couple of hours. About all I have left is to weld my bracing in and get the shaft threaded and keyed. I had plenty of DOM so I cut my tube to utilize the entire 72" shaft. We are going to run it on a 1436 jon boat for now. From what ive been reading around 15 degrees is the best angle for my driveshaft?
If anyone has any suggestions post them up!
Setting up the engine plate
Mon Dec 31, 2012 6:27 pm
Post Re: My longtail build.
Bushings and bearings installed. Ready to set the angle and start on the bracing.
Mon Dec 31, 2012 6:29 pm
I cheated and bought a transom mount from back# water. This thing is real nice.
Mon Dec 31, 2012 6:30 pm
I'd love to know more about your upper bearing setup.
Mon Dec 31, 2012 9:15 pm
If you don't mind. Where did you get your u-joint? Part number? Thanks
Mon Dec 31, 2012 11:54 pm
Quote:
Tue Jan 01, 2013 2:17 am
Tue Jan 01, 2013 10:20 am
Tue Jan 01, 2013 10:21 am
getting close! I will pull the driveshaft and have it threaded and keyed tomorrow.
Tue Jan 01, 2013 5:38 pm
"action shots!"
Tue Jan 01, 2013 6:33 pm
Dose that top bearing take up the thrust load? thanks
Tue Jan 01, 2013 9:47 pm
Not really. There are a couple of set screws that lock the bearing on the shaft. I guess will help a little.
Tue Jan 01, 2013 10:14 pm
looks great !how long did you make the dom tube?
Tue Jan 01, 2013 10:31 pm
I would have to double check but somewhere around 64" I think. I used the full 72" on the drive shaft and cut my tube to fit my needs.
Tue Jan 01, 2013 10:50 pm
Looking good,i plan on building one in the off season.W do you think it weighs?
Wed Jan 02, 2013 9:01 pm
Thu Jan 03, 2013 9:11 pm
Im getting close! I need to put the motor on the actual boat we are going to use it on and cut the handle down, get battery cables on, hook up my kill switch and test it out.
Fri Jan 11, 2013 9:14 pm
very nice build, i don't see how you could have done a better job, it looks great.was your transom mount your design?
Fri Jan 11, 2013 10:38 pm
No I bought the mount from Back # Water inc
Mon Jan 14, 2013 11:20 am
Mon Jan 14, 2013 8:56 pm
First test run today was pretty successful. I forgot the GPS but I was satisfied with the speed I got with two people in the boat. It actually does better with two people than one because the person up front counteracts the weight of the motor. Ive got to redo the handle, it too thin of pipe and we bent it. Ive also got to get new seals for the upper housing. I only used one and I put it in backwards and it lets grease push through to the flange bearing. When it gets warm the grease oozes out.
Sat Jan 19, 2013 8:22 pm
sounds like your first test run was a success,nice job! did you figure out what type of up-grade you are going to do for a handle.
Sat Jan 19, 2013 11:09 pm
I'm happy to report that Ryan 289 build is still working. A friend on mine bought it and I used it this weekend. I am planning on building a exact copy. Ryan 289 you did well.
Wed Mar 30, 2016 1:22 pm
Users browsing this forum: No registered users and 75 guests
