It is currently Mon Jun 23, 2025 2:33 am
Reply to topic  [ 4 posts ]
 20hp honda performance questions
Post 20hp honda performance questions
i have read a few things about trying to get a increase in performance out of the 20hp honda gx620,i seen that i could add the hi rev springs for the valves,gut the exhaust, adjust the carb from running too lean. MY question is, what would yall recommend? Bottom line is i want to get a little more top end out of it. Im not sure what adjustments are needed to "un lean" the carb, and exactly what parts i would need for the valve work. I am currently running a 15x40 crawfish skiff, planning on building a new one around 18x38. Just curious if any of you have any ideas or tips to point me in the right direction
Thu Dec 03, 2015 2:25 am
Post Re: 20hp honda performance questions
I have a gx670, not sure if this will work for yours, but here is what I did. Robertson torque tubes vtwin exhaust kit and welded it up to a y collector and into a tractor style 2" muffler. Main jet went from 98 to 105 and when the carb was off I used a pen torch to remove the epa limiters on the idle mixture screws so that I could remove the lean bog off idle.
On my heavy 18x50 custom I went from 16 mph(occasionally bump 17 when things were perfect) to a solid 20. Bottom end torque was much better than stock.
Good luck bud.
18x50 DFOU custom hull,
backwater kit with gx670 honda,
Robertson exhaust kit,
Work in progress
Fri Dec 04, 2015 8:09 am
That's pretty significant in my book lol, I will wait until after hunting season and see what I can get out of it
Fri Dec 04, 2015 6:34 pm
Send me a pm when you get ready to do it and I will text you pictures of my exhaust and answer any questions I can. Good luck!
Work in progress
Thu Dec 10, 2015 8:31 am
Users browsing this forum: Majestic-12 [Bot] and 36 guests
