It is currently Wed Jul 16, 2025 3:53 pm
[ 4 posts ] |
Help with a longtail set-up
Tcounty
Joined: Wed Jan 14, 2009 4:45 pm Posts: 168 Location: West TN
How low in the water should my prop be running? At wot it is about 1' under the surface, is that right, or do I need to adjust my calvitation plate to make it ride higher? It's on a 1438 jon boat, 13 hp scavenger. I MIGHT be getting 8 mph. It does squat some in the back but I think it's due to the prop being so low in the water. With the handle that is on it I'm sitting in the middle of the boat,
_________________ 1648 old style bass tracker with a...........................
50 Nissian on a 17' Lakesport.
Mon Dec 21, 2009 11:02 am |
lparrish
 Re: Help with a longtail set-up
My cavitation plate runs about 1" under the water. If I adjust it any high it wants to blow out of the water. From what I have read and seen 1" is about right.
Tue Dec 22, 2009 8:55 pm |
gonehunten
that were im running my godevil LT.and if you go to low it hits everything ,it seems.
Tue Dec 22, 2009 9:05 pm |
Tcounty
I can force it ,by pushing down ,to run 1" below the surface, but I loose speed. I think its due to the calvitation plate being angled down. The one on the scavenger is adjustable. It is mounted on studs. All I need to do is put washers on the front studs, and it should point the plate up some, that should raise the prop.
Wed Dec 23, 2009 8:15 am |
[ 4 posts ] |
Users browsing this forum: No registered users and 56 guests |
