| MudmotorTalk.com https://www.mudmotortalk.com/mmt_v2/ |
| Kohler trouble https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=68400 |
| Author: | Mattjw [ Mon Sep 26, 2016 10:25 am ] |
| Post subject: | Kohler trouble |
Has anyone experienced a hot start issue with a Kohler command 25. Mi e will fire right up cold then after running hard it will try to choke out at low idle. Once it is off it is hard to light back off until the motor has cooled down. Usually ends up flooding before I can get it to start. Maybe float stuck on carb? |
| Author: | Will C [ Mon Sep 26, 2016 10:29 am ] |
| Post subject: | Re: Kohler trouble |
Could be time for a leak down test to see how the valves are sealing. |
| Author: | Cajunwannabe [ Tue Sep 27, 2016 5:24 am ] |
Might be an issue with the electronic fuel shutoff solenoid? I took mine out and cut the needle off the fuel shutoff and then reinstalled the solenoid. I've been running it like this for years. Let us know what you figure out, I am running an '02 25 hp Kohler and it's been a good one. |
| Author: | Mattjw [ Thu Oct 13, 2016 4:00 pm ] |
I rebuilt the carb and everything seems to be working good knock on wood. Definitely was some gunk up in there |
| Author: | Will C [ Thu Oct 13, 2016 4:36 pm ] |
Good deal. |
| Author: | Mattjw [ Thu Oct 13, 2016 5:29 pm ] |
Thank you for the help fellas |
