huck Finn
Joined: Thu Jan 31, 2013 5:42 pm Posts: 1913 Location: Conroe tx
 Lever style throttle , 30$ , 20 minutes
Bought a MSR Hp AOF pro clutch lever at local motorcycle shop in town. 30$ with tax . Part number is 34-1686. The clutch lever mounts on a godevil handle with zero modifactions , remove cable , unscrew the two mounting bolts and take off stock throttle lever , discard , install new lever , orientate to your preference, the existing wire from your cable will mount right to internal channel in new lever , this system has a small adjustment wheel that will extend or retract to take all the play out of your cable , you can also adjust at idle by just making a few small clicks right there at the handle. I mounted mine in about the same location as the old throttle. What I really like is the instant throttle response. Did the whole swap in less than 20 minutes. Will see how it works this weekend .
Anybody want pics pm
_________________ Ole black water keep on rolling
18x54 Uncle J -GTR - with the koolaid Back H2o SWOMP 23 SS stage 2 15x36 GD Duck Skiff GATOR GATOR GLIDE PROSTAFF BACKWATER PROSTAFF http://www.gatorglide.com
Coupe rest in peace brother
| Tue Feb 12, 2013 10:02 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
 Re: Lever style throttle , 30$ , 20 minutes
Sweet!!! Screw a pm, post the pics, man
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
| Tue Feb 12, 2013 10:11 pm |
Team Camo
I'll post video once it's uploaded.
| Tue Feb 12, 2013 11:13 pm |
huck Finn
Thanks camo
| Tue Feb 12, 2013 11:19 pm |
huck Finn
I will be the go devil at the back of the pack at the mud run, slow compared to all the sd , but I will be there
| Tue Feb 12, 2013 11:22 pm |
ds541
looks good thanks for the post and pic's,that will be my next upgrade!
| Wed Feb 13, 2013 8:44 am |
TX Aggie '06
Joined: Mon Jul 26, 2010 4:32 pm Posts: 684 Location: Houston TX
Looks good, interested to see how out holds up. I'm tired on my plastic squeeze throttle!
Sent from my MB865 using Tapatalk 2
| Wed Feb 13, 2013 9:00 am |
indawoods
in.
| Wed Feb 13, 2013 9:04 am |
huck Finn
Dealership is Conroe cycle shack on I-45 feeder in Conroe tx , they carry them in stock everyday . Looked around for a while and picked this one because it will fit on existing go devil frame and its heavy duty , hope this helps anybody
| Wed Feb 13, 2013 12:56 pm |
3rd Coast Killer
Joined: Thu Aug 27, 2009 3:17 pm Posts: 2624 Location: League City, Texas. It's where I play.
I like it bud. I'll let you do it to my GTR!
Kool-Aid Brigade
www.southernfowler.com
| Wed Feb 13, 2013 1:11 pm |
AJCsurf
Whats the diameter of that handle?
| Wed Feb 13, 2013 1:12 pm |
huck Finn
I will measure when I get home
| Wed Feb 13, 2013 1:16 pm |
AJCsurf
| Wed Feb 13, 2013 1:18 pm |
BrackIV
Joined: Sat Nov 21, 2009 8:58 pm Posts: 641 Location: SETX
I might add this to my GDLT! Looks clean. One question, wouldnt it work better on the other side of the handle? I'm pretty sure thats how most squeeze throttles are. To each his own though.
_________________ 1854 InstaGator 35 GTR w/ carb and MM exhaust
"Addicted is an understatement" *GEAUX TIGERS*
| Wed Feb 13, 2013 1:20 pm |
huck Finn
Thought about that, this way I can still hold the handle with 4 fingers and just the throttle with my thumb, if I hit something( when I should say) I can just release my thumb and still control handle ,
| Wed Feb 13, 2013 1:50 pm |
huck Finn
Diameter is 1-1/16 inch
| Wed Feb 13, 2013 1:55 pm |
BrackIV
What about turning to the right at a medium throttle? When ya push against the handle, seems like it would push the throttle in more. On squeeze throttle, I usually work it with my pinky finger so I can grip the handle firmly with three fingers and my thumb. But if it works for ya, then great!
| Wed Feb 13, 2013 2:02 pm |
huck Finn
I am going to try it like this to start but , if it's uncomfortable then all I have to do is loosen the two carriage bolts and spin it around, well see .
| Wed Feb 13, 2013 7:56 pm |
ottertailriverrunner
Joined: Fri Oct 02, 2009 4:46 pm Posts: 79 Location: Otter Tail County, MN
Thanks, I have been looking to do this to my gdlt. Let us know how it works
| Thu Feb 14, 2013 8:21 am |
AJCsurf
| Thu Feb 14, 2013 9:11 am |
Jw261
Joined: Sat Oct 22, 2011 12:20 pm Posts: 96 Location: Lower Alabama
Looks good. Let us know how it works out.
| Thu Feb 14, 2013 3:03 pm |
huck Finn
New throttle worked great , came in handy while maneuvering . In the mud just held it wide open. Wish there had been more longtails there , at Setx, only saw myself and two other boats. The conditions were great for sd on our fri afternoon run in both ponds, you could stop and go root it up anywhere. The wind and falling tide made the ponds hell if you lost plane by Saturday , and it kept falling, that's why everybody was stuck. But the longtail really shined on Saturday , you could go accross that skinny water and mudlike nobody's business , I could stop next to my buddies boats , visit a little while , take off and go play all over the back, pretty much anywhere.
Thanks to the two airboat guys. , you really helped everbody out .
| Sun Feb 17, 2013 12:11 pm |
BAG Hunter
hows the new throttle working out? I bought me one today. I will try it out this weekend. Mine is a 35 SD and I hope it works out good. Thanks for the post. I had been trying to go the free route and use and old hand brake off one of my kids old bicycles but the diameter was wrong on it. This should be alot better.
| Thu Feb 21, 2013 9:39 pm |
huck Finn
Worked great , ran fri and sat at Setx 13' , liked that you can control one handed and nice crisp response .
| Thu Feb 21, 2013 10:39 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
I'd like to put a lwver on my pd. I hate the twist throttle.
Sent from my DROIDX using Tapatalk 2
_________________ 1850 & 36pd
| Thu Feb 21, 2013 11:27 pm |
huck Finn
Gonna put one like this on 3ck s gtr
| Thu Feb 21, 2013 11:29 pm |
shooter
_________________ 32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
| Fri Feb 22, 2013 2:47 am |
huck Finn
He'll yes send details , he wants one on his gator tail
| Fri Feb 22, 2013 7:26 am |
med
| Fri Feb 22, 2013 10:17 am |
shooter
Posted new thread instead of hijacking this one. Here's the link... viewtopic.php?f=3&t=37995
| Sun Feb 24, 2013 1:28 am |
guidry21
Joined: Thu Feb 14, 2013 1:33 pm Posts: 338 Location: galliano, la
this is probably a dumb question would this work on my mud buddy i have some crappy throttle and would like that kinda setup
_________________ 16x48 alweld 35 gtr
| Fri Mar 22, 2013 9:42 am |
huck Finn
Work on anything with a throttle As long as it will fit your shaft diameter
| Fri Mar 22, 2013 10:12 am |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
Mine isn't nearly as pretty as what Huck did, but it took about the same amount of time and didn't cost as much. I use either galvanized steel or aluminum strap. It is much easier on my old arthritic hands and improves control. For those of you that question everything, the holes are to make it lighter  and the chunks of bicycle inner tube on the handle are for cruise control when I'm on a long trip.
_________________ so many rivers, so little time
| Fri Mar 22, 2013 11:19 am |
guidry21
i appreciate the info
| Fri Mar 22, 2013 11:28 am |
Gameover
Joined: Tue Jan 03, 2012 9:06 am Posts: 3673 Location: Prarieville,LA
I tried this on a stock GTR and this specific model huck used won't work. The cable isn't long enough to get all together correctly. It can be African engineered but even then it wasn't good.
_________________ 1754 GTR Xtreme CC w/ Purple Kool-aid Additives
| Fri Mar 22, 2013 1:34 pm |
THE TANK
Joined: Wed Mar 04, 2009 7:34 pm Posts: 1080 Location: Coteau Homles, La
I like that, thanks for the info bro....
| Fri Mar 22, 2013 2:13 pm |
huck Finn
Agree with gameover , will work on swapping out existing go devil throttle and hard ware. But the throttle cable on the gt rig has a different set up at the throttle end . It was to wide to fit the inside diameter and slide thru the lever I used .
| Fri Mar 22, 2013 5:49 pm |
coupe1975
MMT Eternal Member - Rest In Peace
Finn, I'll give you one off a old knuckle head frame I have and let you see if that will work. Call me and remind me before we ride next time. The cable hole is to large to work on the gdlt or my new motor
| Fri Mar 22, 2013 6:32 pm |
Bayport
| Tue May 20, 2014 3:14 pm |
coupe1975
You grind off the pinch style button that's on the original godevil throttle assembly. And it will fit perfect into the handle Huck used. I did his mod and it works great. I couldn't get quite enough throw so I moved the handle out some. This also allows you to make the diameter of the mount what ever you need
| Fri May 23, 2014 9:53 am |
