gear reduction swomp lite
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=70072
Author:  mnugent [ Fri Mar 17, 2017 7:57 am ]
Post subject:  gear reduction swomp lite
Hey guys does any one know if the kohler 7hp with 2/1 gear reduction will bolt up the the swomp lite frame i think this would help my small rig out alot
Author:  sleepy_sleeper [ Sun Mar 19, 2017 8:59 am ]
Post subject:  Re: gear reduction swomp lite
I've got a 9hp Honda 2:1 in a Go Devil frame and it isn't meant for speed. It spins a 10x9 prop but only at 1850rpm 10mph empty and 6mph loaded. Unless you are pushing a barge extremely slow I wouldn't use a gear reduction on a long tail.
Author:  flint87 [ Sun Mar 19, 2017 12:38 pm ]
Author:  flint87 [ Sun Mar 19, 2017 12:39 pm ]
Not a worm gear by like a planetary gear
Author:  mnugent [ Mon Mar 20, 2017 3:44 am ]
With to people and gear i cant plane on a 1436 do you think it would help get the load up or would more power be better
Author:  CypressCritter [ Mon Mar 20, 2017 10:52 am ]
I would lean towards that the motor doesn't need gear reduction but the prop pitch and diameter to get the rpms of your motor in the "range". Sometimes less pitch or diameter will help speed and/or load carrying abilities. Back in the day a ran a 16hp GDLT changed from a 14x42 to a 16x44 - got a little more speed and load carrying ability. A loaded 36" will not plane as good as a 44" with the same load nor a 14' vs 16' in most cases. I got 13-15 mph 16x44(standard ribbed 100 ga Lowe) with 2 adults, dog, gear, and 6 dz. decoys.
Author:  sleepy_sleeper [ Wed Mar 22, 2017 3:42 am ]
I would go 16hp minimum if possible.
Author:  Mark F. Cheney [ Sun Mar 26, 2017 8:28 am ]
on a non reduced engine the pto comes off of the crank shaft. on a 2/1 reduction engine the pto comes off of the camshaft. They are in different places on the engine face plate. aside from performance issues - no they will not bolt up on the same frame.
Author:  fireman1293 [ Wed Mar 29, 2017 7:23 pm ]
Author:  mnugent [ Thu Mar 30, 2017 9:33 am ]
Thanks guys i guess im gonna suffer threw another year and than step up to a bigger motor and hull
