How do You Haul your Longtail? https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=8216 |
Author: | quack-addict [ Thu Mar 04, 2010 2:49 pm ] |
Post subject: | How do You Haul your Longtail? |
I just got a new GD 18hp longtail. I ordered it with the swivel bracket, but the way my transom cuts down and then back up, then motor hits when I try to pivot it, and it wont work. Sooooo......I'm out the $75 and I have to figure out a way to haul it down the road as it is. Whats the best way you've figured out to tie the handle, etc to keep it from going up and down and side to side? Much thanks. |
Author: | DeuceChunker [ Thu Mar 04, 2010 3:00 pm ] |
Post subject: | Re: How do You Haul your Longtail? |
Check the pics on this thread... viewtopic.php?f=31&t=7575 |
Author: | quack-addict [ Thu Mar 04, 2010 3:19 pm ] |
That looks pretty solid Thanks Deuce |
Author: | earl33 [ Thu Mar 04, 2010 3:43 pm ] |
Short transom and tall sides dont work well with a swivel bracket.. LIke the other thread shows will work, or depending on your floor lay out get some fold away tie downs.. Mount them to the floor of your boat and hook the ratchet strap to them.. Link to what i talking bout.. http://www.etrailer.com/c-TIE.htm you can get them at Lowes or other hardware stores... |
Author: | macakm1 [ Thu Mar 04, 2010 10:03 pm ] |
Author: | bundy [ Thu Mar 04, 2010 10:18 pm ] |
i have built brackets for people i will get pics up of the ones i built... they r strong and will hold up... that ractchet strap if it pops ur forked ![]() |
Author: | backwaterballer [ Thu Mar 04, 2010 10:40 pm ] |
Go to the auto parts store and buy a 20 dollar bolt on reciever hitch tube bolt it to the back of you trailer and build you a support brace you can slide in and out just by unpinning it. IMG_0141.JPG if I did it right that is a picture of mine |
Author: | EasTexDux88 [ Fri Mar 05, 2010 8:20 am ] |
pic no worky baller |
Author: | sbbrown67 [ Fri Mar 05, 2010 8:24 am ] |
I have this one for sale, but you can see the built in transome saver that keeps the motor from side to side while traveling. All you do is remove two pins and it comes off. Easy Breezy. IMG_1006.JPG |
Author: | backwaterballer [ Fri Mar 05, 2010 8:30 am ] |
Ya I can't figure out how to post a pic from the Iphone |
Author: | earl33 [ Fri Mar 05, 2010 8:33 am ] |
Author: | backwaterballer [ Fri Mar 05, 2010 10:02 am ] |
You can go to my profile and click on 14ft Jon w/ 23 hp gdlt post. There are pictured of my trailer and boat there. My trailer is longer the my boat but it's the same concept I'm gonna do my new boat like that when I getbit on this trailer. |
Author: | b_coonass [ Fri Mar 05, 2010 3:34 pm ] |
Author: | b_coonass [ Fri Mar 05, 2010 3:44 pm ] |
bracket.JPG |
Author: | b_coonass [ Fri Mar 05, 2010 11:05 pm ] |
Author: | fishon!! [ Tue Mar 09, 2010 10:39 am ] |
the problem i have with mine is that when i have the prop inside the boat and tied down (with a ratchet strap connected to trailer and wrappaed around shaft), the shaft still moves up and down and beats the hell outa my hull. i try to keep a paddle or something under it so the skeg hits that instead of the hull. you should be able to get the shaft parallel to the transom, then lean the motor back(to outside of boat), and carefully get the shaft on the inside. unless theres a lot of difference in height |
Author: | macakm1 [ Tue Mar 09, 2010 5:38 pm ] |
Author: | Smoke [ Thu Mar 11, 2010 1:04 pm ] |
That's the same as I have. An eye bolt in the cross member. I built a vee stand out of treated landscape timber. I put the handle of the mm in the vee, bungie it down and then wrap a heavy duty strap around the handle then attach both ends of the strap to two eye bolts on my trailer. I put some black plastic pipe split in half over my gunnel tubes so I don't rub the damn paint off all the time. I took me a couple of years repaintin it to finally figure out a way to keep that from happenin. ![]() S |
Author: | Jim1648 [ Mon Mar 15, 2010 7:07 pm ] |
http://www.mudbuddy.com/Store%20specifi ... 0Spec.html |
